jaguar s type problems
Old May 27, 2012 | 09:50 AM
Jaggemeister's Avatar
Cool Check for Original coils
Make sure your mech technician applied original coils. If you put some Ford replacement coils, there is a thread that is not the same measure and the ground cable will not reach a neutral current so will not work. This rpm unstable are very common after coils and its plugs had been damaged by passing heavy rainfall accumulation. If you want to hear the failure to make sure is firing problem, take the trac control off and put the gas to a drag speed take off, you will hear the missed firing. It should burn some tires if engine/transm is ok.
Old May 28, 2012 | 05:23 PM
nightowlchucky's Avatar
Thanks for all who tried to help , I have now pushed her over a cliff and she is now lost to the sea , I have had two jags now with exact same problems with both , my jag days are now well and truly behind me good luck to all the die hard jag fans but never again for me I'm afraid , like I said not for me does not mean not for you all thanks again .
Old May 29, 2012 | 08:45 AM
JagV8's Avatar
Poor repairs = push car over cliff? Well, your car, your choice, but proper repairs would be much cheaper and far better IMO.
BTW, you're going to be doing the same with non-jags and for the same underlying reason.
Old May 29, 2012 | 11:25 AM
Old May 29, 2012 | 08:17 PM
Hello, i Had that problem. I tried everything. Computer always went to same cylinder. Everything was new. You know what was the problem? Replacement coils and plugs, not original ones. The screw slightly changes. I put original ones and i can burn my tires again with the trac control off and some heavy take off!
Old May 30, 2012 | 08:02 AM
barcheta's Avatar
Mercedes is like this too. Must. Use. O.E.M.
Old May 30, 2012 | 10:57 AM
abonano's Avatar
+1 on OES coils for Jaguar... expensive but well worth it!
Old Jun 8, 2012 | 06:25 PM
  #28
sl3972's Avatar
what is the name of the part that holds the fender liner to the fender it is the fastner which has teeth that bite into a lip on the insied of the outer fender with a screw hole at the end which you can then attach by screw the inner fender lining
Old Oct 12, 2014 | 01:08 PM
Anfieldman's Avatar
Default Started happening
Mine has recently started doing same. Ticking over nicely at a standstill then will just cut out. Also revs up and down at standstill. Any advice?
Old Oct 12, 2014 | 01:30 PM
  #30
joycesjag's Avatar
Yes, you can add your vehicle details to your signature so we don't have to waste our time asking what year, engine etc.......
Oh and welcome to the forum. You might want to stop by the "New Member" area and properly introduce yourself per forum protocol.
Old Oct 12, 2014 | 07:57 PM
  #31
abonano's Avatar
check my posts - I posted that part number...
Old Oct 13, 2014 | 09:13 AM
  #32
richard toulouse's Avatar
All,
I am interested to know the end of the story as my S have similare defect since.... 4 years without any solution. The only positive aspect is that I saved fuel.......
The idle is instable. No fault code and lake of power.
What is the correct range value I should read on 02 parameter with an OBD tool?
Old Oct 13, 2014 | 09:31 AM
  #33
JagV8's Avatar
Of the various faults claimed, which one(s) do you mean? Best start a new thread just for yours. Also say whether the tensioners have been changed to the metal-bodied ones and (if you know them) the fuel trims at idle & about 2500rpm (engine hot, parked).
Old Oct 13, 2016 | 11:10 AM
  #34
Stewart Moncrieff's Avatar
Default restricted performanve
At slow speeds my s type diesel goes into limp mode. The fault code indicates accelerator pedal. Have tried a new pedal...problem remains. Crazy thing...I can drive for 50 miles no problem. Then suddenly this problem starts and continues for upto 30 minutes. Anyone any ideas or solutions?
Old Oct 13, 2016 | 11:16 AM
  #35
JagV8's Avatar
Code is....?
Old Oct 13, 2016 | 11:21 AM
  #36
Mikey's Avatar
Start a new thread, giving complete details of the car and the event instead of tacking on to someone else's old dead post.
Old Oct 13, 2016 | 11:28 AM
  #37
Thanks Il check with garage for the code.
stanjag
Dec 29, 2024 08:26 PM
nelsonht
Aug 30, 2015 06:01 AM
swarm27
Aug 29, 2015 07:37 AM
NorJag
E type ( XK-E )
Aug 28, 2015 07:31 AM
Terrance Williams
Aug 26, 2015 11:50 AM
