Jaguar s type r cooling Help!
Old Oct 11, 2017 | 11:41 PM
Jaguarstype's Avatar
Unhappy Jaguar s type r cooling Help!
Hi, Im new to jaguars, got myself a 2005 s type R love it but it needs some work
so i have a Couple of questions.
Dose anyone know were this hose goes? I think its on the water pump manifold.
And also the bottom hose/line of my Coolant Reservoir Tank I don't know exactly were its supposed to go, And maybe links on where i can buy the lines?
also my transmission dosent like to go to 4 and 5 gear, 1 2 3 gears work fine
it like its gose in but slips out idk what is it? maybe a rebuild?
Old Oct 12, 2017 | 05:29 AM
JagV8's Avatar
The full cooling diagrams are in JTIS - which you appear already to have (top diagram is from it). Free download if not.
Start with fuel trims as any minor engine issue can upset the trans.
If close to zero, check or more likely change trans fluid (& filter etc) - see the threads about how to etc.
Old Oct 12, 2017 | 05:13 PM
IV tried getting the manual by downloading it but it dident work could you find me or just tell me where they go?
Old Oct 12, 2017 | 05:25 PM
Its this hose but i dont know were it gose
Old Oct 12, 2017 | 05:40 PM
Joedotcom's Avatar
hi
STR coolant circuit
looks like hose between 9 and 10
cheers
Joe
Old Oct 12, 2017 | 05:43 PM
NBCat's Avatar
The hose the red line appears to follow goes to the DCCV, which is mounted near the bottom of the radiator on the RH side of the vehicle. There is also a supercharger coolant pump mounted near the DCCV.
Old Oct 13, 2017 | 12:46 AM
Oka so I think I'm going to need to buy #10 sux pump
i have a hose connected from 9 dose anyone know where I can buy the hose on the bottom of my coolent expansion tank?
Old Oct 13, 2017 | 08:55 AM
NBCat's Avatar
You can try one of the vendors listed in the 'Marketplace' tab at the top of this page.
SNG Barratt are generally a good source for most items: SNG Barratt - The Ultimate Jaguar Parts Specialist
