JTIS Not working at all... "Windows 7" I need Help!
Old Nov 8, 2010 | 05:24 PM
mystype04's Avatar
Unhappy JTIS Not working at all... "Windows 7" I need Help!
I've been experiencing a problem with my JTIS CD. I've contacted the Ebay Seller and even after a second CD and a drirect online download, I still not able to use the JTIS Program...
It says "A problem caused the program to stop working correctly, Windows will close the program and notify you if a solution is available.. So what’s going on? I need to work on my car ASAP!
My computer has "Windows 7" and with the new CD the problem persists. Maybe there is something I’m doing wrong?
Can somebody help me?
Thanks,
JG
Old Nov 8, 2010 | 05:32 PM
Sean B's Avatar
Ah, I don't think it works with Win7, have you an old laptop or pc with XP on it? that should do it...
Old Nov 8, 2010 | 06:05 PM
DittoGlen's Avatar
Is your Win 7 64 bit? (x64)
If so, it will not work.
The only way to get it to run on x64 is to run it within a Virual PC with a 32 bit (x86) OS.
Virtual PC is a free Microsoft product, but you'll have to install an x86 OS like XP within that VPC, and install JTIS within that OS.
Old Nov 8, 2010 | 06:23 PM
Mafioso's Avatar
doesnt W7x64 have a compatiblility mode.
If you right click on the exe goto properties and check for x32 compatibility mode.
Old Nov 8, 2010 | 06:59 PM
DittoGlen's Avatar
Compatibility mode will not help with installing DAO.
DAO is a Data Access Library which is only available in x86, it will not install in x64.
JTIS uses DAO which is severely outdated, and deprecated.
There is a manual CD available which is web based, and does not rely on DAO, see my thread on JTIS alternative.
Old Nov 8, 2010 | 07:28 PM
vance580's Avatar
Mine works with Windows 7 but I am running 32bit. I got a direct download of the images and burned those to cd's so I have to have the cd's in order for it to work but it works perfect. I'll try and see if I can find out where I dl'ed them from.
Old Nov 8, 2010 | 08:06 PM
RizwanSharp's Avatar
+1 on that.
I'm running the same setup. JTIS is not supported on Windows 7 x64.
Solution is to install Microsoft Virtual PC and under that virtual PC, install Windows XP x86 and on that windows install ur JTIS.
It should work like a charm.
Let me know if you need more info.
Thanks,
Rizwan
Old Nov 8, 2010 | 09:52 PM
mystype04's Avatar
Im too running the 32bit Windows 7... Humnnn, maybe I can try what you did.
JG
Old Nov 9, 2010 | 12:16 PM
clubairth1's Avatar
Community Influencer
I run Win 7 Ultimate N (64 Bit) and use the virtual machine to run JTIS. Works great! The virtual machine software was a free download from MS.
Old Nov 9, 2010 | 01:20 PM
Mikey's Avatar
You have the Ultimate or Professional versions of W7. Virtual PC is not available to us owners of the lowly Home Premium version.
Old Nov 9, 2010 | 01:57 PM
JagV8's Avatar
Some files are PDF so you don't need anything special. Many others are .SGM (SGML) so are text with mark-up. Slightly awkward to read but just open them in anything that handles text files (Office, notepad, wordpad, whatever). Saves buying yet another windoze licence.
Wonder if it installs under WINE in Linux - completely free if so.
Really helpful of Microsoft to dump DAO thereby stuffing their users - again. Can't think why one of my mates has dumped Microshaft n bought a Mac Mini. His son already moved to Linux.
Old Nov 10, 2010 | 09:07 AM
If Virtual PC is not supported on Home Premium, you can try VMWare (same thing diff brand :P).
Hope that helps.
Thanks,
Rizwan
Old Nov 10, 2010 | 01:40 PM
DittoGlen's Avatar
During the install of VPC on my Vista Home Premium x64 an error dialog appeared saying something like "not designed for this OS", or "Will not install...", or some such thing.
There is an [ignore] button that I clicked, and it installed and runs fine on my Vista Home Premium.
The VPC is free, can't lose for trying ...
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
philwarner
Sep 5, 2015 10:05 AM
TC Johnson
Sep 2, 2015 09:30 AM
