Key programming 2003 s type r
Old Oct 7, 2019 | 02:04 AM
Bethoumy's Avatar
Default Key programming 2003 s type r
Hi all, I replaced my window regulator on the drivers side of my 03 S-Type R today and shortly after, I used the remote lock and came back to the car an hour later and the remote didn't work.q I then proceeded to manually unlock the door, which, in turn, triggered the alarm until I inserted the key into the ignition. After all that the key worked fine until I tried it again an hour later and the same thing happened. Any fixes?
Old Oct 7, 2019 | 06:41 AM
JagV8's Avatar
The key part is as per design. If you fix the window properly it should go back to working as it used to do.
Old Oct 7, 2019 | 09:30 AM
motorcarman's Avatar
Once again Jaguar TSBs are your friend!!!!!!!!!!!
bob
File Type: pdf
File Type: pdf
Old Oct 7, 2019 | 10:47 AM
scottjh9's Avatar
bob
Amen bob
Terry
General Tech Help
Dec 4, 2012 02:37 PM
Sinister 1
Jan 26, 2010 09:41 PM
joebit
17
Sep 23, 2009 01:03 PM
dEo_and_bigcat
Mar 5, 2008 11:55 AM
