Knocking noise?
Old Mar 3, 2013 | 12:06 PM
Stanners's Avatar
Default Knocking noise?
Got a new balljoint for my s type. Went to fit it yesterday and turned out the balljoints on the front was loose do just tightened them up,balljoints themselves are fine and don't have any play in them.. So balljoints are fine,nice and tight,but the knocking noise from the front end is still there! Any ideas what a common problem for knocking noises on s types could be?
Also.fitted a new shocker and the NSR Is still squeaking when I go over a bump? It's obviously a bush gone but can't seem to see which one.. Any common bushes that go on the rear anyone know?
Thanks in advance
Old Mar 3, 2013 | 12:15 PM
Gus's Avatar
Gus
Not sure why it was loose but you want to check it again. The reason I say that is when it was loose it might have elongated the channel it is in that could prevent it from seating properly allowing it to come loose again.
Old Mar 3, 2013 | 12:18 PM
Stanners's Avatar
The lower arm looks like it has been replaced as it had a date stamped on it as though it was from a breakers yard. I'm thinking when it was fitted the balljoint wasn't tightened up correctly! But within seconds it was knocking after being tightened.
Old Mar 3, 2013 | 12:35 PM
JagV8's Avatar
ARBs (anti-roll bar bushes).
sway bars to those over the Atlantic
JimC64
31
May 30, 2016 03:04 PM
LnrB
Oct 13, 2015 12:45 AM
inactualis
Oct 2, 2015 11:13 AM
baskervillema
Oct 1, 2015 06:43 PM
