Left front sign lamp failed temporarily
Old Nov 10, 2009 | 04:07 PM
bombu's Avatar
Default Left front sign lamp failed temporarily
Hello there,
I just got this S-type V8 4.2 (NOT R). And the Left front sign lamp is sometimes on and sometimes failed.
Certainly when it failed, the warning sign will tell you, then suddenly after some left turn signaling, it is fixed again.
Could this be due to the wiring failure ? or may be just the bulb is not tight enough ? Any idea ? Thank you in advance.
Old Nov 10, 2009 | 04:16 PM
I'd take a look at the bulb holder, mine burnt up the terminals.
Old Nov 10, 2009 | 04:22 PM
phd12volt's Avatar
remove bulb, take needle nose pliers and pinch the terminals together, then reinsert bulb making sure it is tight. problem should be fixed. I already had to do this on mine.
Old Nov 10, 2009 | 04:23 PM
bombu's Avatar
Thank you Norri.
If it burnt up the terminal, does it cost a lot to replace ?
Old Nov 10, 2009 | 04:24 PM
tbird6's Avatar
My 2005 S Type had the same bulb/socket problem. I looked carefully and saw a small slot had been burned in the metal spring clips in the socket that holds the bulb. Changing the bulb did not fix it. I finally folded aluminum foil over until I had a small square of flexible metal. I folded this over the bulb base. Then plugged the bulb into the socket making sure the small piece of foil stayed in place. That was over 5K miles ago and it works fine. I just can’t find used parts for these cars!! There just are not enough of them around!!
Old Nov 10, 2009 | 05:01 PM
bombu's Avatar
Thank you very much PhD12Volt, and tbird
I will try that.
Old Jan 3, 2011 | 06:43 PM
RizwanSharp's Avatar
I'm having the exact same issue. Can you please tell what you did to fix it.
Is it safe to drive the vehicle till weekend without causing more damage?
Thanks,
Rizwan
Old Jan 4, 2011 | 05:02 PM
I took the bulb out cleaned everything up, tweaked the wire terminals a bit and Bob's your uncle, the real solution will be a new bulb holder, I didn't price them but read somwhere that they are pretty pricey.
Old Jan 4, 2011 | 09:35 PM
Thank You so Much Norri, I'll give it a try on the Weekend and hope it works for me... If it does not then I'll look how much the new holder is going to Cost (don't know if that kind of thing will be covered by the Extended warranty).
Anyways. Thanks for the heads up. I'll repost after doing what you have suggested.
Best Regards,
Rizwan
Old Jan 4, 2011 | 09:59 PM
Best Regards,
Rizwan
Old Jan 6, 2011 | 08:24 PM
clubairth1's Avatar
Community Influencer
If you can get the socket please post back to the list. I never could get one for my 2005 passenger side front turn signal.
Old Jan 6, 2011 | 09:26 PM
I don't know how it could be different for Left and Right.
But this is what I got from Jaguar Catalog posted by some on forums:
LEFT Side Turn Signal Bulb Holder: Part# XR848363
http://www.oempartcatalog.com/partlo...&siteid=214578
RIGHT Side Turn Signal Bulb Holder: Part# XR812401
I haven't open the holder yet so I don't know If I can fix the exiting one or need a new holder.
Please let me know if it helps.
Thanks & Best Regards,
Rizwan
Old Jan 6, 2011 | 10:08 PM
clubairth1's Avatar
Thanks for the links but they don't go to any parts? Just the search page?
Old Jan 7, 2011 | 04:25 AM
joycesjag's Avatar
club, I went to the link(s) listed and copied and pasted the part #s in the search box and came up with the parts and price.
Old Jan 7, 2011 | 08:58 AM
Sorry for that. I didn't verify that those links actually go directly to the part page.
Please do what joycesjag said you'll get it.
Thanks joycesjag.
Best Regards,
Rizwan
Old Jan 7, 2011 | 05:43 PM
Those part numbers brought up headlight levelling motors for me.
Old Jan 7, 2011 | 09:40 PM
See the attached Pic... take from Catalog.
I gave those Part numbers from this catalog and that Holder is highlighted in number 16 (in the picture).
You can call those guys and ask them if thats the actual holder of the Turn Signals.
I hope that helps.
P.S: this is what that website says:
Front lamps - Headlamp components - Levelling motor - Holder
Signal lamp bulb Left - Halogen 2003-07 2003 - 2007
Rizwan
Old Jan 7, 2011 | 10:34 PM
Mafioso's Avatar
We sell aftermarket bulb holders at NAPA if anyone is interested I can get a P/N and price
Old Jan 8, 2011 | 07:01 AM
I'm interested if you can find some info.
I think mine will need changing before too long.
Old Jan 8, 2011 | 10:18 AM
clubairth1's Avatar
RizwanSharp;
Sorry my mistake!! Thanks for the part numbers!!
Mafioso;
That would be great if NAPA carried them! Please post back if you find out.
dsnyder586
Dec 29, 2024 07:39 PM
PMKimpton
Aug 3, 2019 08:22 PM
afterburner1
Dec 16, 2015 12:12 AM
jdzubas
Oct 4, 2015 09:14 AM
Tar
Sep 6, 2015 11:24 AM
