Limp mode
Old Apr 28, 2025 | 09:03 AM
ChadH44's Avatar
Default Limp mode
I have a 2005 Jaguar S-Type sedan 4 door
it went into limp mode and I can’t get it out of limp mode. Anyone have this problem with there S-type
Old Apr 28, 2025 | 09:07 AM
JagV8's Avatar
It's rare and a sign the car is protecting itself (& you) from potentially serious damage.
Try a decent OBD tool and see if there are codes and also whether any of the live data look wrong.
Old Apr 28, 2025 | 10:55 AM
NBCat's Avatar
+1 on seeing if any DTCs are stored.
Many random instrument cluster warnings and DTCs are the result of a failing or weak battery. Use a voltmeter to check the available voltage across the battery terminals with the ignition in the OFF position for at least thirty minutes. If the voltmeter indicates less than 12.6 volts, charge the battery for five hours at 2 to 5 amps and retest. If the voltmeter still shows less than 12.6 volts, the battery should be replaced.
XKDreams
Jun 12, 2024 04:31 AM
davebaileys
Jul 6, 2017 12:09 PM
slurveystj
Jun 27, 2014 10:19 PM
joec
Dec 22, 2013 08:22 AM
Jon89
58
Jul 7, 2009 10:02 AM
