Limp Mode and Dash lit up like a Xmas Tree!
Old Feb 5, 2013 | 12:43 PM
  #41
JagV8's Avatar
I wouldn't rush to blame the TB.
I'd buy a cheap OBD tool such as elm327 because they are REALLY good and cheap, then you can read your own codes and other data.
If I were going to change a TB on a 4.0 I think I'd get a used one. But this is assuming it's to blame and it may well not be. There are a lot of other things that can fail...
It's more likely to be a bad battery or coil, for example.
Old Feb 6, 2013 | 06:22 AM
  #42
JagMaSteR0917's Avatar
Once again i have never seen a battery make a car go into limp mode. Now the p2135 code will. 05 and earler stypes with code p2135 will need a throttle body to be fixed. Sorry
Old Feb 6, 2013 | 06:25 AM
  #43
Throttle body easy to replaced but not cheap. P.s evap codes will not set car into limp mode.
Old Feb 6, 2013 | 06:26 AM
  #44
I may be able to help you fine TB just let me know
Old Feb 6, 2013 | 08:32 AM
  #45
GonzoJag's Avatar
Thanks. I will let you know.
Old Feb 6, 2013 | 09:08 AM
  #46
carelm's Avatar
What about cleaning the TB itself and making sure all the connections are good?
Old Feb 8, 2013 | 01:00 PM
  #47
GonzoJag's Avatar
Another Update: Installed a new battery on Monday. My son let me know yesterday that the CEL went dark on Thursday. We'll see if it stays that way, but as of now all is good and it appears the issue was a bad battery. Looking back, I should have told him to return the old battery to Autozone and have it tested. That would have told us a lot. At any rate, I asked him to take it to Autozone this weekend and have the codes read to see if there is a repeat of the P2135.
BTW...thanks again for all your help!
Old Feb 10, 2013 | 11:12 AM
  #48
Docuzzie's Avatar
These cars are heavily dependant on electronics. The battery or a flailing alternator not producing sufficient current can generate the limp home mode and a ton of other codes, including but not limited to, transmission failure, brakes, DSC failure, engine failure, Cats failure etc etc.
Jagged-X
Sep 24, 2015 05:08 PM
shootingbrake
Sep 23, 2015 10:54 AM
Jdthomas
Sep 23, 2015 06:23 AM
Dixie61
Sep 19, 2015 06:29 AM
tsimms7
Sep 15, 2015 12:43 PM
