Lingering noise in the engine after ignition off
Old Jan 1, 2019 | 03:26 PM
JaguarJacks's Avatar
Had trouble figuring out the dinamics of the tensioner too !
where can I find all that good info ?
Old Jan 1, 2019 | 05:20 PM
Gonna drive this Jag on 226 F until someone gives me an answer
Old Jan 1, 2019 | 06:00 PM
scottjh9's Avatar
Go to the stickies page... multitude of info there...did you find the previous leak and does the radiator tank have a black plastic bleed screw...I am not real familiar with the 3 liter engine....check on jagrepair.com....alot of info there also
Old Jan 2, 2019 | 09:13 AM
NBCat's Avatar
If you don't have the Workshop Manual for your X200, you can download it here:
https://www.dropbox.com/s/jp6343385h...e_FSM.pdf?dl=0
Hopefully you used an OEM thermostat and the housing is fitted correctly.
Review the bleed procedure for getting air out of the cooling system. Also use the information Brutal provided on the other thread you started.
Old Jan 2, 2019 | 10:28 AM
kr98664's Avatar
Um, this sounds like the equivalent of threatening to hold your breath until you turn blue. Not going to help you much. Not everybody can reply right away. Patience, please.
Old Jan 6, 2019 | 04:16 PM
Old Jan 6, 2019 | 04:18 PM
Alright Alright
Gentlemen , how’s That for my average running on idle temps in Fahrenheit ?
Old Jan 6, 2019 | 04:36 PM
  #28
JagV8's Avatar
Something's weird. Fuel trims 0 (why?) and 6 DTCs. What are they???
OL-FAULT is also bad news.
Be afraid.
No idea why you're asking about temperature when the car's in the worst distress I've seen for months or years.
Can you not find a proper tech and fast before you write the car off?
Old Jan 6, 2019 | 04:51 PM
NBCat's Avatar
+` on misfire(s) and other DTCs.
IAT is for the inlet air temperature, not coolant or in the case of the 3.0 litre, cylinder head temperature (CHT).
Why are STFTs and LTFTs at 0.0?
Old Jan 6, 2019 | 06:40 PM
  #30
Old Jan 6, 2019 | 06:43 PM
  #31
What do you think ?
Old Jan 7, 2019 | 03:30 AM
  #32
JagV8's Avatar
You're ignoring the posts telling you what to do.
Posting more pics but ignoring people is just wasting your and our time.
Old Jan 7, 2019 | 07:12 AM
  #33
Okay then , let me put it to you like this
the readings on the computer vary depending on idle and drive mode so the second and DIFFERENT set of pictures is what it showed me on drive
>>>>> OL FAULT vs CL FAULT
>>>>>SHRTFT&LNGFTzero vs SHRTFT&LNGFT18.5&19
And since I’m kinda grateful to this community for heads up with overheating issues that I had no clue about , I’m also keeping my cool replying to the ‘weird’ comments
Do you understand me now , ‘JagV8’ ?
Old Jan 7, 2019 | 09:24 AM
  #34
NBCat's Avatar
You need to find and fix the cause(s) of the Open Loop. The ECM is compensating by making the mixture extremely rich. If you don't find and correct the air leak(s) and misfire(s), catalyst damage is the result.
If the MIL is flashing, catalyst damage is occurring.
What DTCs are stored? Post them here so suggestions on corrective actions can be given.
Old Jan 7, 2019 | 10:15 AM
  #35
JagV8's Avatar
As I said you're ignoring people e.g. posts #28 & 29.
Taking yet more pics just wastes more time.
Old Jan 7, 2019 | 11:49 AM
  #36
scottjh9's Avatar
Read the codes and post them...looks like car is keeping system in open loop fuel control...codes will give us more pinpoint info...pics show you have definite problem, but now need the dtc codes
Old Jan 7, 2019 | 10:15 PM
  #37
Pending
Last edited by JaguarJacks; Jan 7, 2019 at 10:17 PM. Reason: Erased the codes yesterday to refresh the system
Old Jan 7, 2019 | 10:18 PM
  #38
That a few hours past erasing the codes to refresh
Old Jan 8, 2019 | 04:02 AM
  #39
JagV8's Avatar
Check / change the O2s. It can't do anything right with the engine if they're bad.
Old Jan 8, 2019 | 08:49 AM
  #40
I’ve already changed a couple of O2 sensors or the drivers side not too long ago (paying attention to the random codes while the Lshape hose under intake manifold has been busted)
