Loose fuel cap
Old Jan 18, 2013 | 11:20 PM
Bad Cattitude's Avatar
Default Loose fuel cap
I let my son pump gas last time we filled up. He left the fuel filler cap loose and the next day I got an indicator light and message on the dash. The check engine light was also on. I stopped the car and tightened the cap. Te indicator lamp went off and the message was gone from the display, but the check engine symbol is still lit.
Do I have to do something to turn it off or do I have another issue?
Old Jan 19, 2013 | 02:20 AM
JagV8's Avatar
It needs a couple more drive cycles and then should self-clear. Code will remain stored for ages so clear it if you're bothered. Any cheap OBD tool. Now so cheap really everyone should get one...
Old Jan 19, 2013 | 08:12 AM
bfsgross's Avatar
Yep, ten on/off cycles of key.
Old Jan 19, 2013 | 10:59 AM
JagV8's Avatar
No. Not of the key.
Old Jan 19, 2013 | 11:29 AM
bfsgross's Avatar
Cel?
Old Jan 19, 2013 | 09:32 PM
Thanks! It did self-clear sometime today.
Old Jan 20, 2013 | 08:06 AM
totalimmortal363's Avatar
I was always under the impression that OBDII will self clear after three drive cycles, meaning running in closed loop, without the fault present.
Old Jan 20, 2013 | 09:01 AM
JagV8's Avatar
Clears the MIL, yes.
Russ Graber
Feb 23, 2019 11:59 AM
Papelione
Sep 21, 2015 06:13 PM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
jagent
Sep 12, 2015 09:10 AM
AL NZ
Sep 4, 2015 08:39 PM
