Loud Squeaking?? Steering Shaft?
Old Aug 27, 2016 | 04:38 PM
S-TYPE06's Avatar
Default Loud Squeaking?? Steering Shaft?
Anyone ever experienced loud squeking while turning wheel in 2006 S Type? Removed front wheel and found that sounds seem to be coming from steering shaft.. this gets very embarrassing when people are staring at how beautiful your car is until you get to turning the wheel and a loud squeking starts to happen. Thanks in advance
Old Aug 28, 2016 | 09:07 AM
Mikey's Avatar
Very common issue. The squeak is from the steering rack itself, not the steering wheel or shaft.
The fix is simple. Follow this:
https://www.jaguarforums.com/forum/s...62/#post276860
Old Aug 28, 2016 | 10:16 AM
motorcarman's Avatar
If you can hear it OUTSIDE the car, then it is likely a ball joint.
bob
Old Aug 28, 2016 | 11:59 AM
S-TYPE06's Avatar
Thanks for your input I'll start with the additive tomorrow morning since it'll be simple. The I'll try the ball joints since I noticed the noise is louder when the car is on the ground then It was when the car was jacked up
Old Sep 3, 2016 | 08:10 AM
S-TYPE06's Avatar
Update: Replaced outer tie rods because they were very worn out... nomore noise coming from behind the wheel.
Thanks for you'll input
robearner
Apr 2, 2016 03:51 PM
steve12955
Mar 27, 2016 05:09 PM
Humy
Oct 8, 2013 10:38 AM
chprman
May 1, 2008 05:23 PM
Interior
Jan 24, 2007 04:50 PM
