Is the Lower control arm bushing the same as a ball joint?
Old Oct 31, 2012 | 06:36 PM
daboss085's Avatar
Default Is the Lower control arm bushing the same as a ball joint?
I need to replace my lower control arm bushings. I already did my upper control arms and my ball joints. now my mechanic says I need lower control arm bushings. Please if someone can help me, also with a part number. thanks
Old Oct 31, 2012 | 07:05 PM
QuartzSTypeR's Avatar
There is a lower ball joint in the lower control arm, but its not the same as the bushings.
Old Oct 31, 2012 | 07:22 PM
In a word, NO.
The bushings are the rubber things at the inner pivot of each lower arm, usually 2 per arm.
The balljoints are on the end of the arm, right out near the road wheel, usually 1 per arm.
The bushing number I have here is JLM 021535, and you will need 2 per arm.
ym37tech
Feb 8, 2016 01:04 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
JagLove86
Sep 6, 2015 10:36 PM
