"The Lurch" Theory
Old Oct 22, 2009 | 09:17 PM
  #81
StrateLoss's Avatar
it will get better once you hit around 100 city miles or so. 3 times i did hard reboot, 3 times it got better after 120 miles or so. im in nyc where everything is stop n go
Old Mar 11, 2014 | 07:49 AM
  #82
roger.grote's Avatar
Hi I have a 2007 S Type sport and have experienced sudden bang when going to accelerate fron not quite stopping first,do you think that a reflash is called for and has any one got an approx price for this service,
Ta
Old Mar 11, 2014 | 07:56 AM
  #83
JagV8's Avatar
May well work. Call around, prices vary a lot. Done right they have quite a bit to do including driving the car with 2 people.
If it doesn't fix it then may be short on fluid which is more painful to check let alone fix.
Old Mar 11, 2014 | 08:21 AM
  #84
Jon89's Avatar
Check your transmission oil cooler lines (there are two of them) at the crimped fittings where the metal piping transitions into the rubber hose section. Given the age of our cars now, a number of owners are seeing ATF weeps and leaks at these locations. Since you must remove the belly pan to inspect this area, most owners do not catch this issue until it has been ongoing for months or longer. You may be well short on ATF now as a result, and that could be causing your lurch issue....
Old Mar 11, 2014 | 09:49 AM
  #85
Mikey's Avatar
Ta
Sounds very much like classic lurch. Whether a reflash will fix it permanently or not is uncertain. Somes car respond very well, other do not.
Old Aug 30, 2016 | 04:59 PM
  #86
webshark's Avatar
I have this issue on my 2010 XFR, most places I've talked to are saying the Mehcatronics need replacing? I dont want to jump into that and potentially messing things up if thats not whats needed.. Hoping to find someone around LA familiar with these issues..
Old Aug 30, 2016 | 05:50 PM
  #87
JagV8's Avatar
This is not the XF forum so it's doubtful that more than a few will know to what extent the S-Type knowledge applies. It may well not, especially as the XF was introduced after the lurch was known and fixed on the S-Type.
Old Aug 30, 2016 | 05:55 PM
  #88
Mikey's Avatar
Sounds like classic Lurch to me.
https://www.jaguarforums.com/forum/x...g-stop-168427/
Sleestak
Sep 24, 2015 03:00 PM
Lawrence
XJ40 ( XJ81 )
Sep 18, 2015 02:03 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
XFR_Gold
Sep 2, 2015 12:24 PM
XFR_Gold
UK & Eire
Sep 2, 2015 06:30 AM
