Misfiring - RESOLVED
Old Nov 29, 2012 | 12:55 PM
Stanners's Avatar
Default Misfiring - RESOLVED
Right then..
Got my S type 3.0 V6 manual,80K on the clock,year 1999
Has a misfiring problem which is intermittent. The car was parked up for 7 months and he said it was running fine before with no problem and now its on the road it's misfiring. Am I right in saying its a common problem to be coilpacks and easier to replace all 6 plugs and coilpacks? OR what would be the chances be for it to be the MAF sensor? Or is coilpacks the more likely cause?! I've had a fault code reader plugged in and nothing comes up neither is an engine management light on.
Opinions would be greatly appreciated.
Many thanks
Matt
Last edited by GGG; Dec 2, 2012 at 05:08 PM. Reason: Add 'RESOLVED' to thread title
Old Nov 30, 2012 | 03:03 PM
jimgoose's Avatar
Earlier S-Types at least suffer a bit with the coil-over-plug modules. Does this misfire happen in wet weather, by any chance? In my case it started like that, before the offending unit broke down completely.
Old Nov 30, 2012 | 05:52 PM
Matt,
(I've moved your question to the S-Type section to get more views by members with the same model.)
A misfire with no codes is very strange but replacing all six coil packs and plugs is a costly way of troubleshooting and not guaranteed to fix it.
Hope the guys here can come up with advice and suggestions.
Old Nov 30, 2012 | 08:58 PM
bfsgross's Avatar
Hi Matt. A weak but "not totally down and out" coil can cause a misfire without setting off a code. Swapping in a new coil cyclinder to cylinder till offensive misfire ceases is one method.
Old Dec 1, 2012 | 02:27 AM
JagV8's Avatar
Will have P1111 or P1000, regardless - which does it have?
If P1000 it's not ready to start flagging most codes, so won't flag misfires.
Old Dec 1, 2012 | 02:26 PM
gordon8677's Avatar
Default misfire
Hi, when my s type misfired it was a coilpac (number3),over 40mph really bad. had all the sparkplugs changed and the coil but should have replaced all the coils really.
Old Dec 1, 2012 | 02:47 PM
Stanners's Avatar
All done Replaced all coilpacks and plugs - problem sorted.
Now the right hand of the block has had recent plugs,whereas the left side under the inlet havnt been done for at least a few years. The chap I got the car off said its been serviced last year. Well.. The 'mechanic' was obviously snidey and replaced just the x3 on the right hand side of the block and I guess didn't fancy taking the inlet off to do the others!
Man thanks for everyone's help and opinions for the cause of my problem.
Old Dec 1, 2012 | 07:52 PM
bfsgross's Avatar
Righty then! Yer on yer way.
aode06
Jul 28, 2023 02:26 PM
pnwrs2000
Nov 17, 2015 04:04 AM
reb1999
Sep 26, 2015 08:41 AM
