more front wheel bearing questions
Old Mar 21, 2020 | 01:17 AM
ian.fox's Avatar
Default more front wheel bearing questions
Hi guys. I need to change my front wheel bearings on my 02, and I'm a little confused by some of the terminology in some posts I've read. I *think* when people say they've replaced the front wheel bearing, they mean they've swapped out the entire hub/bearing assembly? Are the bearings a serviceable item (like older cars like my TR6)?, or is the only option a hub swap? More confusing is guys mentioning prices of around $40, but the hubs I've found on ebay are around $300? I understand I'm up for a bit of a battle removing that hub, but once out, can I swap any bearings, or do I chuck it out? I can't seem to find any reference to the procedure in my manual either.
cheers
Ian
Old Mar 21, 2020 | 03:15 AM
JagV8's Avatar
I think the hub is easy (and may be cheaper from a dealer than ebay) whereas the bearing needs a press almost no-one has and great care.
Old Mar 21, 2020 | 03:26 AM
Agreed,
Front hub assembly on the S Types.
NOT hard, many things to remove before the 4 bolts for the hub R&R. About 6 beers per side.
I got mine, a while back, from CBC, and I think? $180 each.
Being in Geelong, talk to Doug at JagDaim, he be the man.
Old Mar 21, 2020 | 03:46 AM
ian.fox's Avatar
Thanks Grant, just shot him an email.
cheers
Old Mar 21, 2020 | 07:48 AM
joycesjag's Avatar
Here is a good read:
https://www.jaguarforums.com/forum/s...removal-53275/
Grant, I did ours in less than 1 beer in my bathrobe, haha
Old Mar 21, 2020 | 09:22 PM
MAAAAATE, ya gotta SLOOOOOOW down.
I recently did the serpentine belt on the X Type, STUPID layout, and that went 10 beers.
Old Mar 21, 2020 | 09:25 PM
cheers
Ian,
Just a heads up, JagDaim's lookup system is Vin based, so send Doug the last 6 of your Vin, which will be M*****. That way time will be saved by his not asking for it.
Old Mar 22, 2020 | 12:44 PM
Aarcuda's Avatar
cheers
Ian
yes. for the front you replace the hub/bearing ASSEMBLY.
For the rear, you cant actually press out the bearings and press in new ones
Old Apr 14, 2020 | 10:46 PM
ian.fox's Avatar
So. I picked up this unit from ebay, and it seems to be in good nick. I'll just need to transfer my brake baking plate. Problem is, I now discover it's for a diesel car? Does it make a difference? It seems strange they would change a component like this.
The part number is 2W93-3K186-E.
wierciu
Sep 8, 2019 10:57 PM
03Xtype
Oct 19, 2015 06:25 PM
2meke
Jul 2, 2013 03:36 PM
tenativelyproud
Mar 20, 2013 03:29 PM
RidenXj8
Mar 13, 2013 09:38 PM
