My dash cracked with pic!!
Old Nov 15, 2013 | 04:29 PM
Diamondrmp's Avatar
Default My dash cracked with pic!!
Hey all this just cracked a couple of days ago. Would this be associated to me getting a new windshield? I ask because I just had a new windshield put on 2 weeks ago.
Old Nov 15, 2013 | 04:46 PM
manycars's Avatar
Coincidental at least......
Old Nov 15, 2013 | 04:51 PM
tbird6's Avatar
That's not your dash. It's the demister panel. Many threads about this. I just replaced mine with a new one from Jaguar. Expensive like all Jaguar parts at $380.
Most likely the mounting tabs underneath are broken which will give you a rattle. Rattles drive me crazy so at first I took it off and added some foam weather stripping but with heat and time the plastic will fail. Once the mounting tabs break off underneath the entire panel vibrates like a drum on top of the dash.
Don't buy a used one as they will also be in the same shape. You can remove it and do a fiberglass repair but it won't look very good. Several people have done that. Pictures have been posted so searching should bring them up.
Most likely yes but to be fair the plastic does get delicate after all this time. You might complain to see if they will replace it. Check out how to remove it because that's where a lot of them get broken. You MUST remove both A-pillar covers first. A lot of people just try to pry it up and pull it out. This is a guaranteed way of breaking it!!
Old Nov 16, 2013 | 03:19 AM
Diamondrmp's Avatar
Grewat info thank you.
Ok it wasn't the glass shop then. I've been noticing a little rattle that seemed to be coming from that general area for some time before replacing the windshield.
Old Nov 16, 2013 | 08:08 PM
FreshJag's Avatar
Bummer! Mine is cracked and rattles aswell. Oh well, it's the price we pay to drive such a stellar vehicle.
Old Nov 16, 2013 | 08:09 PM
Michael Star's Avatar
Mine cracked a year after I bought the car. No rattles but I hate the way it looks
Old Nov 16, 2013 | 11:15 PM
QuartzSTypeR's Avatar
I don't have a crack, but I do have a rattle from there. I may have to give this repair a go at some point...
Old Nov 17, 2013 | 12:11 AM
I don't have a crack or a rattle but I do need to change the solar sensor, will my luck hold?
Old Nov 17, 2013 | 12:58 AM
Diamondrmp's Avatar
Its too bad mine didn't crack before I had the windshield replaced. Probably would have made it a snap to replace!
Old Nov 17, 2013 | 07:20 AM
clubairth1's Avatar
Community Influencer
Something with pictures might help??
https://www.jaguarforums.com/forum/s...-repair-70534/
cyber3d
Sep 15, 2015 02:37 PM
Ipc838
Sep 13, 2015 03:27 PM
jaggermang
Sep 8, 2015 07:07 PM
kstevusa
Sep 7, 2015 01:12 PM
ftypel
Sep 5, 2015 10:15 PM
