My Jaguar S type gearshift stuck in P position and will not engage in to D
Old Jul 4, 2018 | 05:56 AM
Vjay's Avatar
Default My Jaguar S type gearshift stuck in P position and will not engage in to D
I was parked and my automatic gear shifter was stuck in park. it won't come out of (p). But It did eventually came out. I drove the car and stopped putting back in park, pressed brake and went to put back in drive and it was ok. But It did get stuck other times. Can someone please help me
Old Jul 4, 2018 | 06:21 AM
JagV8's Avatar
More car details needed!
Old Jul 4, 2018 | 07:20 AM
Etypephil's Avatar
It will most likely either be the switch operated by the brake pedal which ensures that the pedal is pressed prior to selecting a gear from the park position, or the relay adjacent to the gear lever (under the centre console) which is the second part of the system. Either can fail, but frequently a liberal dose of electrical contact cleaner sprayed on both will solve the problem. If that doesn't do the trick, check for an output from the pedal operated switch; if you have 12 volts, then the gear lever relay is at fault, if not, it's the pedal switch.
Old Jul 4, 2018 | 09:53 AM
kr98664's Avatar
Yes, please, more specifics are needed.
What year is your car?
Early models ('99-'02) have a 5 speed transmission. 4 is the number displayed at the bottom left corner (D=5) of the J-gate bezel. This model has trouble with the transmission sticking in P if parked on an incline without the parking brake set.
Late models ('03+) have the 6 speed, with 5 displayed at the bottom left corner. This model has trouble with the bolts working loose that attach the shift cable to the transmission housing, but I don't think that would lock the shift lever.
Also, when the shifter is stuck in P, how far can you move it? If you can only move it about halfway to park but seems to hit a solid stop, that's the interlock within the J-gate not releasing for reasons unknown. If the shifter feels springy, as opposed to hitting a solid stop, that's a different problem.
Old Jul 4, 2018 | 10:34 AM
NBCat's Avatar
There were several TSBs issued to address the gear selector being stuck in the 'P' position:
http://jagrepair.com/images/TSB/TSB2...%20Release.pdf
http://jagrepair.com/images/TSB/TSB2...ck%20Lever.pdf
http://jagrepair.com/images/TSB/TSB2...h%20J-Gate.pdf
Some refer to the 5R55N and others to the 6HP26/28.
Digital Will
Feb 21, 2026 05:58 PM
RayR
Sep 26, 2022 04:43 PM
Colquan1066
Jul 23, 2019 12:15 PM
hunterpedigo
Jun 21, 2017 08:59 PM
hunterpedigo
Oct 29, 2015 05:31 PM
