My shifter solenoid has gone bad. I need an affordable solution.
Old Feb 4, 2013 | 12:19 PM
Candy's Kitty's Avatar
Default My shifter solenoid has gone bad. I need an affordable solution.
I'm using a flat head to get the car out of gear for the moment. I'm wondering if I can get the solenoid out of the assembly and replace it without replacing the entire assembly.
I believe the check engine lite is on as a result of the solenoid failure. Can I remove it all together and replace it with a resistor or maybe even just secure the piston in the unlocked position?
I have a 2003 S-type
Old Feb 4, 2013 | 03:08 PM
abonano's Avatar
I've heard of hot wiring this solenoid - but I would look into getting a replacement assembly from a boneyard.
Old Feb 4, 2013 | 04:04 PM
cbharley10's Avatar
Default Replacement Shifter
Hey there!
Check your previous post (the one with all the pictures) I posted a couple of options for you that are both less than $100 with shipping!
Cheers!
n2audio
19
Jan 20, 2025 09:35 PM
adam699
Oct 13, 2015 05:53 PM
Johnken
Oct 2, 2015 10:12 AM
Johnken
Oct 1, 2015 05:07 PM
