Nav screen black
Old Oct 28, 2011 | 08:11 AM
fogey0's Avatar
Default Nav screen black
The nav screen stays black on start up every once in a while on my 06 STR. Usually on restart it comes back on. Doesn't happen a lot just from time to time. Anyone know what the cause is?
Old Oct 28, 2011 | 08:53 AM
JagV8's Avatar
Sounds like a bad connection (electrical or optical).
Old Oct 28, 2011 | 12:22 PM
havnfun's Avatar
Yes I have had the same problem......actually happend when I was driving and using the Nav to get me somewhere ! The screen went blank and the nav unit was dead, I just kept driving and eventually it came back on.
Old Oct 30, 2011 | 07:40 AM
The Chris X's Avatar
That has happened to me maybe 2 or 3 times. Restarting the car gets the screen to boot up. Unless it starts happening with more regularity, I'm chalking mine up to just a glitch. I've taken the unit out and checked all the connectors/reconnected. Didn't find anything lose, but I suppose there could be something I missed back there.
Old Oct 30, 2011 | 10:36 AM
clubairth1's Avatar
Community Influencer
Kind of suspicious that we have 2006 STR's doing this? Wonder if it's software related rather than hardware??
Old Nov 5, 2011 | 09:43 PM
WhiteXKR's Avatar
My S-type does that maybe one out of every hundred starts. I just accept it.
Old Dec 11, 2012 | 06:50 AM
Staatsof's Avatar
Default The darn thing just likes being rebooted.
Mine just did this for the first time this morning.
I disconnected the battery and everything is fine again.
Given the number of times I've had to disconnect the battery on this car to either reset the car for something like this or other issues I've decided it's time for a quick disconnect switch on mine.
This has to be the single most valuable service tool/method I've found so far with this car.
Old Dec 11, 2012 | 07:34 AM
Michael Star's Avatar
Mine had the same issue before I reflashed it. It did it 3 times in a year and a half. Since I went with a 09-10 disc, it hasn't done it again.
Old Dec 11, 2012 | 10:08 AM
MyBlackCat's Avatar
This also happened to our 06 STR when we first got it for about a year.
The blue Tooth phone also would not work at the same time.
There is a TSB on this problem. Can't remember the number but it is in the stickies.
Ours was outside the VIN range but the dealer did it anyways and corrected the problem.
IIRC after reading the TSB I believe that it tells you how to access the current version on your unit just to see if you have the old software or the newer software.
Give it a look.
Old Dec 11, 2012 | 04:40 PM
clubairth1's Avatar
My 2005 STR with the 2011 maps has never done that. Maybe the software version is the problem?
Old Dec 11, 2012 | 05:21 PM
Staatsof's Avatar
Mine has done this once in the 2.5 years I have owned it. If gets to be repetitious then I'll look into it. For now a battery cut-off sounds great. That lets my car forget all of that horrible around town driving, it's like an instant tune-up!
I've just come to expect a few electronic gremlins with this car.
I had a couple in a 90s Q45 but far less than this.
My 2001 Ford wagon occasionally misbehaves as well and I just slap it around a bit and everything is fine again! Come to think of it I just got doing the same exact thing to my DVD player in the Jag when it wouldn't release the magazine. Must be a Ford thing ...
Majik Lasers
Aug 2, 2024 01:49 AM
trosty
26
Dec 18, 2022 06:40 PM
captbob73
Oct 24, 2015 05:49 PM
texaspete
Sep 10, 2015 08:34 AM
Quebecjag
Sep 10, 2015 06:06 AM
