Need to replace fender.. how does fiberglass rocker panel come off?
Old Jul 2, 2013 | 08:12 PM
Jaguar S Type's Avatar
Default Need to replace fender.. how does fiberglass rocker panel come off?
Greetings! My S Type got hit in the left fender so I must replace it. This car has a fiberglass rocker panel cover that runs from wheel well to wheel well. I can remove the screws in the bottom clips but something is holding it on from the top. Are there hidden screws or is it a matter of getting a blade under it to pop hidden clips? Or is it glued or taped in place?
Many thanks! I don't want to break anything.
Tom in PA
Old Jul 3, 2013 | 04:06 AM
thebiglad's Avatar
Just plastic clips once you've removed all the screws.
Old Jul 3, 2013 | 06:14 PM
Thanks Dave, but is it just the clips with the screws on the bottom? How is it held on at the top in the door jambs?
Does anyone have a photo or diagram of where all the clips are?
Old Jul 3, 2013 | 06:53 PM
Originally Posted by Jaguar S Type
................ Does anyone have a photo or diagram of where all the clips are?
Tom,
You don't have sufficient posts (minimum 10 required) to be able to download PDF's from the forum so I've put the JTIS Front Bumper Removal section on my MediaFire account. You can download it using this link:
http://www.mediafire.com/view/94tejf...mper_Cover.pdf
It's a 1.2mB PDF. has removal/replacement instructions with diagrams.
Old Jul 3, 2013 | 07:25 PM
Graham-
Thanks for the front bumper removal info. It will come in handy, but the bit of info I was looking for was the same info on removing the left front fender (guard) and the fiberglass rocker panel under the doors. The bottom fender bolt is behind this.
Tom G
Old Aug 5, 2013 | 09:42 PM
GTS308's Avatar
Hi Tom...You probably have worked this out by now..but!
Once you have removed all the bottom screws, open both doors and starting at the rear pull the rocker panel using the black mini mud flap.
Pull this straight out from the car as there are other plastic locating tabs that just push into holes..about 8 from memory..these are moulded inside the rocker..
Once you get the first couple to pop it will come of easy...
Old Nov 16, 2014 | 06:45 PM
mkrion's Avatar
Great info here, however I had a couple of the clips break off as they were quite brittle during the rocker panel removal. I have downloaded the electronic parts catalog but cannot locate a part number for these. Does anyone have the correct part number or a clip that will work frm another make. Thanks in advance.
Mike
Forcedair1
Sep 8, 2025 01:57 PM
cissdm
May 3, 2016 06:02 AM
KarimPA
Sep 12, 2015 08:15 AM
obwoodie
Sep 3, 2015 07:45 PM
KarimPA
Sep 3, 2015 07:32 PM
