New guy out of Atlanta GA.. I come to forum with problems
Old Oct 11, 2012 | 05:16 PM
Phat535's Avatar
Default New guy out of Atlanta GA.. I come to forum with problems
My wife has a 2003 S-Type 3.0L.. The problem is leaking coolant.. I was told it was coming from the electric pump to the heater core.. I took some photos (down underneath the resorvoir, top and bottom view) and I see coolant. Just wanted to confirm if this is the pump and 2ndly can it be repaired by a DIY or have to go to shop?
Thanks in advance of responses and look forward to being part of the forum.
Attached Thumbnails New guy out of Atlanta GA.. I come to forum with problems-jag-part-top.jpg   New guy out of Atlanta GA.. I come to forum with problems-jag-part-bottom.jpg
Old Oct 11, 2012 | 05:53 PM
welcome aboard Phat535, good to have you here with us here at JF
I've moved this to the S type section for better results, also included your pics in post so you can get the best help available
Helpful_information
Check out the regional section for your area?
Old Oct 11, 2012 | 05:59 PM
Welcome to the forum Phat535,
You'll want to check the tech section S-Type / S type R Supercharged V8 - Jaguar Forums - Jaguar Enthusiasts Forum and maybe take a look at the regional section Lower Atlantic - NC SC FL GA - Jaguar Forums - Jaguar Enthusiasts Forum
It's not the pump, the V6 doesn't have one.
The part in the picture is the DCCV dual coolant control valve.
If you go to the tech section and search for those terms you'll have plenty to read.
It's a fiddly but straightforward repair, you can get a Ford valve cheaper than the Jag part, but you will find all that info along with part numbers and pics in the tech section.
Old Oct 11, 2012 | 07:37 PM
Excellent advice from Norri. He's done everything bar come round and fix it for you!
Hope you soon have the control valve replaced and the S-Type is running sweetly again.
Old Oct 11, 2012 | 10:41 PM
bfsgross's Avatar
Welcome phat535. Ditto to all and do it quick cause a blown DCCV can toast the climate control module. If it did this already, when the a/c is on you'll have cold coming out of some vents, heat the others. RockAuto.com sells the DCCV (same as Lincoln LS) for $80.
Old Oct 12, 2012 | 07:47 PM
Phat535's Avatar
Awesome! Thanks all for the replies. I will find the part and try my luck at installing. Keep you all posted.
I will post photos of my wife baby Jag soon.
fast40driver
Apr 19, 2024 07:24 AM
flyc2c
Jan 15, 2016 05:30 PM
ogorir
Sep 3, 2015 07:34 PM
tony bosco
Sep 1, 2015 02:06 PM
Tony Bow
Aug 28, 2015 05:17 AM
