New Jaguar S-Type Owner
Old Sep 12, 2015 | 03:41 PM
ZJag's Avatar
This is what my handbook says in my Jaguar. Any thoughts? I believe what I'm looking at is correct..
Old Sep 12, 2015 | 04:05 PM
Jon89's Avatar
That is NOT an oil change interval. That is telling you to expect your new engine to require around 3,000 miles for normal break-in. You may not have the "Passport To Service" booklet that came with your car when it was new. In it, the oil & filter change interval is indeed specified at 10,000 miles....
Old Sep 12, 2015 | 05:06 PM
ZJag's Avatar
Ohhhh okay! That's good then.
By the way, whenever I turn on my left signal, the Autolamp turns on..but not on the right. It says, "Autolamp Delay 2:00". But right as my signal clicks off it goes away.
Old Sep 13, 2015 | 09:26 AM
JagV8's Avatar
It's 10K / annual so if only going 6K/yr then change it then.
There will be "slack" (engineering tolerance) in these figures i.e. you could stretch them to longer but why would anyone...
Old Sep 14, 2015 | 02:30 PM
tbird6's Avatar
Please start a new thread about your Auto lamp display.
I have seen this on my 2005 every once in a while. I think it's a problem with the turn signal stalk but mine does not do it very often so I tend to forget about until I see it again.
Old Sep 4, 2016 | 02:46 PM
irlsunny's Avatar
Originally Posted by Mikey
As are the 10K interval owners, AFAIK.
The interval chosen by the OEM is not an ultimate ragged-edge limit- it's an already conservative number designed to encompass even the lowest common denominators. This ensures that premature engine wear due to contaminated oil does not become a reliability issue- not that Jag ever had experience with those.
Reducing that figure yet again is double belts and suspenders.
If you really want to take care of your baby use the new Pennzoil Platinum synthetic motor oil. It is made from natural gas and it will clean your engine with the new detergents that can be used with the natural gas formula. This oil has also proven to have almost zero wear on engine components after 100k miles. Good stuff .
Old Sep 5, 2016 | 03:33 PM
Mikey's Avatar
Just like the ordinary 5W30 non-synthetics that many of us (including the dealers) have used since day 1.
stanjag
Dec 29, 2024 08:26 PM
ControlIssues
Sep 3, 2015 07:38 PM
dpappyp
Aug 27, 2015 06:31 AM
mkrion
Aug 26, 2015 11:43 AM
NinoGrimace
Aug 26, 2015 05:15 AM
