No cabin heat
Old Aug 29, 2010 | 01:35 PM
xbrit's Avatar
Default No cabin heat
Their is no cabin heat from either side of the vehicle. The AC works fine.
the last owner (I have just purchased it) said the Jag dealer said it was the heated core! Their is no coolant lose. Any input?
Cheers,
Old Aug 29, 2010 | 09:06 PM
JOsworth's Avatar
Will need more info. Model year, Engine, what troubleshoot methods the dealer used to make the conclusion that it is a faulty heater core. A stopped or clogged core could not deliver heat yet not leak either....
Old Aug 29, 2010 | 10:00 PM
xbrit's Avatar
S-type 2001 V8... I am at a loss to their conclusion, but if the heat only does not work I was wondering if any one else had experienced this problem!
Cheers,
Old Aug 30, 2010 | 01:33 AM
JagV8's Avatar
Only way to know who's had it before is to use the forum Search.
You could have a stuck DCCV.
Old Aug 30, 2010 | 02:22 AM
Probably not, as default for the DCCV is open i.e. supplying heat, the chances of it sticking wide open are unlikely.
I'd be inclined to look at the heater core, but I've been wrong before.
Old Aug 30, 2010 | 02:34 AM
JagV8's Avatar
Yes, that's right but they do also stick closed occasionally
Old Aug 30, 2010 | 02:19 PM
xbrit's Avatar
Assuming it could be a DCCV sticking how can I check this?
Old Aug 30, 2010 | 03:52 PM
You could clamp off the inlet hose to the DCCV then disconnect the outlets and loosen your clamp to check for flow through the v/v. You could also try the same thing with the heater core or use a hose.
Old Aug 30, 2010 | 09:13 PM
xbrit's Avatar
the plumbing seems a night mare where is the inlet to the DCCV and or in the inlet to the heater core?
Sorry for my ignorance.
Old Aug 30, 2010 | 11:30 PM
There are pictures here somewhere, search for DCCV, AC problem etc.
Old Aug 31, 2010 | 08:31 AM
JagV8's Avatar
and get workshop manual
Old Aug 31, 2010 | 09:12 AM
Gus's Avatar
Gus
See if this helps http://www.gusglikas.com/images/Auto...g%20Repair.pdf
Old Aug 31, 2010 | 02:03 PM
xbrit's Avatar
Unfortunately being a new member I don't have the privilege to view pictures.
Old Aug 31, 2010 | 02:15 PM
Gus's Avatar
Gus
Copy and paste a link to my page www.gusglikas.com/autorepair.htm and go to A/C 2000 S-Type to the right see if this works for you.
Old Aug 31, 2010 | 03:12 PM
I think you need 10 posts, why not hop over to the off topic section and post on a couple of the sticky waste of time threads?
aode06
Jul 28, 2023 02:26 PM
Delta66
Oct 4, 2015 05:40 PM
Newark Nj Gang
Oct 2, 2015 02:39 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
