No Ignition... Help Troublshooting Please
Old Sep 19, 2016 | 09:54 AM
Siebert22's Avatar
Default No Ignition... Help Troublshooting Please
Alright so this is a 2000 s-type 4.0 with about 95k...
About a week or two ago it started throwing a code, p1388 "valve/cam timing over retarded bank 2, check ECM wiring". It actually went on and off for about a week. The guy at Autozone said right away, you need a new ECM(lol?) It was running great so I decided to just let it slide for now until I had more time to get into it.
Here's where it goes bad. Yesterday I was crossing a bridge on the way up one side I went to give it some gas to climb that hill like a V8 kitty should and it revved really high without shifting... So i let off the gas and reengage, it seemed to shift and all was fine. then on the way down the bridge I realized my power steering was out and was like damn she stalled??? First time shes ever stalled one me.
So I proceed to try and start her I am cranking good so right away I'm thinking there's no fuel being pumped. After about 5 minutes of trying maybe once a minute I turn her over with the pedal floored I got her to catch revved her to like 5k and when I let off the gas she died again...
Looking to get a tow today and was wondering if you guys had any suggestions. I think if it was a fuel pump then I wouldn't have been able to get her to start even a little bit yesterday so I'm ruling that out. ECM maybe? Is there some sort of fuel regulating module I should be aware of? Any ideas on troubleshooting procedures?
I work and go to school full-time so getting this kitty purring is my number one priority atm shes my only transportation option. My dad is going to bring an OBD2 reader to see if shes throwing any more codes later.
Thank you all for your time and replies!
Old Sep 19, 2016 | 01:11 PM
Siebert22's Avatar
update... got it home, disconnected the battery charged it and threw it back in. after about 10 attempts of starting it while holding WOT i got it to catch... running rough and wont idle sounds really rattley with some clanking... timing belt slapping around? bad tensioners?
Old Sep 19, 2016 | 01:12 PM
Siebert22's Avatar
i knew it was potentially coming, but i wasn't expecting it right now lol...
Old Sep 19, 2016 | 01:46 PM
Siebert22's Avatar
soooo... how ****ed am I?
File Type: zip
Old Sep 19, 2016 | 04:16 PM
Mikey's Avatar
I don't know anybody that would download and open a .zip file from a random stranger. I sure won't. Try posting whatever you've got to YouTube.
These engines don't have timing belts. How long ago did you check/change the chain tensioners?
Old Sep 19, 2016 | 05:11 PM
Siebert22's Avatar
Well... Timing chain... I'm sorry. I will try to find another way to post the video, I only put it in a zip because it wasnt in a format approved by the forum
Old Sep 19, 2016 | 06:24 PM
Siebert22's Avatar
here is a more acceptable format... I'm pretty sure its a tensioner
File Type: wmv
Old Sep 19, 2016 | 06:51 PM
abonano's Avatar
Your very ****ed...
Pull both valve covers off and inspect.
If your lucky it might have jumped a tooth but based on your description I wouldn't be too hopeful...
Sorry
gtjoey
Oct 1, 2016 05:37 AM
95Leaper
Sep 26, 2016 08:22 PM
fox5mx101
Sep 19, 2016 01:07 AM
oddjob2000
Sep 15, 2016 04:15 PM
reichstall
Sep 15, 2016 06:50 AM
