Noobee Questions????
Old Nov 3, 2010 | 08:24 AM
zogg's Avatar
Default Noobee Questions????
just bought my 1st jaguar and love it....2006 S-type 3.0
I have a couple of questions I have not seemed to find the answer to by searching the forum.
What type of coolant should I use to replace what is in the car? I have seen several references to Dexcool...orange. Is that the correct stuff?
I have seen several references indicating that synthetic oil shoould not be used in the 3.0....I was planning to use Castrol Edge 5w30, but that is, of course a full synthetic....opinions?
What are most folks using for an oil fiter. I bought a Motorcraft FL400s, and have used Motorcraft parts for years without issue....anything better?
Seems that there are 2 ways to go with the tranny pan. A replacement with a built-in filter and a regular replacement filter....is one better than the other? I know the atf for these cars are expensive (Shell mineral oil)...best place to find it???
Thanks in advance for any and all replies....
Dave
Old Nov 3, 2010 | 09:00 AM
Mikey's Avatar
Welcome to the group! Your post might get locked by asking about oil types (big no-no here unless you ask in a Pirate voice, Aarrrrrr!), best advice is use what you like but don't expect to see any miracles to 'prove' that the other guy was wrong.
I use Dex-cool.
Old Nov 3, 2010 | 09:11 AM
bfsgross's Avatar
Welcome aboard! Dex orange coolant is correct. Simply check owners manual for oil. I used fully synthetic in my 02 X-Type 3.0. Ford oil filter is correct; the 3.0's short block (heads are Jaguar) is a Duratec (Ford). I just purchased the trans. pan/filter/gasket kit along with 8 quarts ZF trans. fluid because I'm about to do a trans. fluid change on my 03 STR. Check the recent trans. service threads for the on-line company that sells the trans. service kit and detailed info. regarding how to perform the service correctly.
Old Nov 3, 2010 | 04:07 PM
zogg's Avatar
Thanks for the replies....not trying to start an "oil war"...ugh
I'll go with the Dex orange as advised....thanks again
Old Nov 3, 2010 | 04:46 PM
jag79's Avatar
Dex cool link for Jags; compatibility Ford WSS-M97B44-D
http://www.shamrockchicago.com/PrestELAf.html
redgear
Sep 18, 2015 10:05 AM
SeanU
Sep 18, 2015 08:09 AM
kamiar
Sep 17, 2015 06:30 PM
pnwrs2000
Sep 17, 2015 04:04 PM
DustysSon
Sep 13, 2015 04:17 AM
