Now another problem!!!
Old Aug 21, 2014 | 07:13 AM
clubairth1's Avatar
Community Influencer
Along the same lines. I have found Propane works good too. I point the unlit torch around the area in question. Also no mess!
Old Aug 21, 2014 | 08:07 AM
JagV8's Avatar
Originally Posted by earico
^ Yep. Tried and trued vacuum leak finder. I use carb cleaner. Engine idles up then you found your leak. Old school for the win.
It can fail to find some leaks but is otherwise OK if used with caution (ventilated space is wise!).
I suspect it wouldn't find a small leak in the hose buried under the intake in a 2000MY 3.0, yet you'd see there was a leak via OBD live data.
Old Aug 21, 2014 | 10:14 AM
Gus's Avatar
Gus
I use Throttle Body cleaner it is a lot safer.
Link http://www.jagrepair.com/images/Auto...otos/P0171.pdf
Clamdigger
Sep 12, 2015 03:43 PM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
