OEM Sirius question
Old Feb 6, 2010 | 01:47 AM
marc4sgr's Avatar
Default OEM Sirius question
How do I get the OEM Sirius on?
Meaning what button do I have to push to get it to play through the stereo.
Its on but all I can do is switch through AM/FM/CD
Old Feb 6, 2010 | 03:05 AM
JagV8's Avatar
What are your car details? Where are you? What's a Sirius?
Old Feb 6, 2010 | 01:02 PM
marc4sgr's Avatar
2007 STR
Sirius as in Satellite Radio
its was an option and my car and installed from the factory
just cant figure out how to dial it in!
Old Feb 6, 2010 | 05:10 PM
MyBlackCat's Avatar
have you subscribed and paid for the service?
Old Feb 6, 2010 | 07:02 PM
marc4sgr's Avatar
Yes. Is it controlled via FM Modulator or is it direct?
Pretty awful setup. I turned on the FM frequency portion and it works.
Shame they couldn't make it work in the Nav Screen and it sounds awful
Unless I'm doing something wrong..??
Old Feb 7, 2010 | 08:40 AM
JagV8's Avatar
Did you try the site search? Might find something useful.
Old Feb 7, 2010 | 01:07 PM
marc4sgr's Avatar
yeah I searched sirius and found nothing about how to set it up.
Old Feb 8, 2010 | 06:13 AM
JOsworth's Avatar
It is pretty straight forward..... I have it and it sounds just as good as any other add on. It wasn't factory installed. All Sat. radio setups are an accessory. Search my posts, I've linked instructions before. One of your problems may be the frequency it is set up on. Also, the unit will have it's own volume control. Make sure you set it to an unused FM frequency and don't set the unit's volume to max, a few notches below should work fine. You will see a volume drop from standard FM to Sirius, but that too is typical. I've entertained wiring it as an aux, but that won't improve the sound all that much. Had one hooked to the Honda I had before the Jag and it sounded about the same.
Old Feb 8, 2010 | 03:58 PM
marc4sgr's Avatar
Thanks for the info!
that pretty much clears it up.
Appreciate your help
H20boy
Dec 24, 2024 03:23 PM
Aus V8S
Nov 13, 2015 11:01 AM
1964Daimler
Sep 9, 2015 11:28 AM
jfitzoz
Sep 7, 2015 04:28 AM
XCrossWindsX
Sep 5, 2015 10:58 PM
