Oil cooler hose for X202 (S-type V8R)
Old Apr 11, 2024 | 11:57 AM
Jean-Michel's Avatar
Default Oil cooler hose for X202 (S-type V8R)
Good morning,
By any chance, someone should have already worked on the oil cooler hoses for an S-Type V8R, (XR843462 and XR843463) and noted the diameters (inside and torus) of the lower O-rings and upper part of each hose (in case they are different).
If this is the case and the measured values ​​are safe, I would be interested to know them, because these parts are no longer available.
Thank you for your comeback.
Sincerely,
JEAN MICHEL
Old Apr 13, 2024 | 03:16 AM
bydand's Avatar
Sorry not reached that project as yet.
https://parts.jaguarlandroverclassic...oler-hose.html
Below are a couple of options.
https://jagspares.co.uk/modern-jagua...ler-pipes.html
https://www.sngbarratt.com/English/#...ds=%5B13714%5D
The difficulties, are in removing the oil cooling pipes, without breaking the fittings and or the securing bolts.
Once removed, the pipes can be refurbished by a local hydraulic pipe repair shop, if not one of the options, new as suggested above..
Fla Steve
Aug 22, 2023 03:33 PM
Robbo D
Jun 8, 2023 12:25 PM
perfectphoto
Mar 3, 2020 02:30 PM
rperformance
Jan 4, 2016 03:13 PM
Bhpbug
May 23, 2015 07:39 AM
