oil pressure
Old Jun 14, 2012 | 08:04 PM
Gus's Avatar
Gus
Could it be that you were not given full access and that is why the links are not working? Have you given an introduction yet? Jim need to make a fix.
Old Jun 15, 2012 | 01:19 AM
JagV8's Avatar
Originally Posted by Sal16
Guys, called the dealer this morning, the don't show any reflash on my records so scheduled to go up there tomorrow morning and they will do it - Hope this works!
My PDF reader seems to be working so I'm still at a loss for the link shutting down windows on me. I'll be in touch anyways
Then just download the PDFs and read them offline.
Old Jun 15, 2012 | 12:38 PM
Sal16's Avatar
Just got back from the dealer, they said the reflash did not work. They say it's either worn out inside or sludged up. They suggested driving it til it dies cause a rebuild would be too expensive. Just changed oil again and put some ATF in - going out for more driving. ( Gas is killing me...). Anybody here of "Sea Foam"?
Old Jun 15, 2012 | 01:22 PM
JagV8's Avatar
How can the reflash not work???? Change dealer!
Stay away from seafoam and I think it won't help anyway.
Old Jun 15, 2012 | 02:01 PM
I have no idea if seafoam works or not, but it won't help you with your problem.
The reflash is to rectify false flagging of codes, if these codes are real I suppose you could say that the reflash didn't work.
I think your best bet is to continue with the flushing / cleaning procedure and hopefully clear out the gunk.
Old Jun 15, 2012 | 02:26 PM
JagV8's Avatar
Let us be clear about "reflash did not work" - I understood it to mean that the attempt to reflash failed. Is that what was meant?
Old Jun 15, 2012 | 05:36 PM
abonano's Avatar
Agreed, stay away from the seafoam - you have 2 options: Option 1 - stick with the 5W20 & ATF combo and drive Option 2 - Pay to get the top end of the motor apart to clean out the VVT passeges/ replace the VVT actuator unit...
Sorry to hear the re-flash didn't address the VVT issues - As Norri pointed out the P1388 must be a "real" code...
Old Jun 16, 2012 | 07:38 AM
  #28
Sal16's Avatar
Took car to dealer; re-flash didn't do the trick. They have nothing else they can do except rebuild or repalce. Told me to just drive it until it doesn't run anymore. Can't do that, can't reregister it because it won't pass emmissions in our state with fault on. Anyone hear of "Sea Foam"? Supposed to ungunk things. I only have a 10 temporary plate on to try and resolve this
Old Jun 16, 2012 | 07:51 AM
Seafoam is supposed to de-gunk the inlet tract, injectors, valves etc.
If gunk is your problem it is internal to to the oilways, so the flushing, atf treatment is the way to go.
Old Jun 16, 2012 | 08:25 AM
  #30
JagV8's Avatar
Everyone says stay away from seafoam.
If it's a fault, try the ATF or disassemble and replace I suppose.
Old Jun 16, 2012 | 04:57 PM
  #31
NBCat's Avatar
To gain access to the VVT units on either inlet camshaft requires removal of the front timing cover, which is an extensive operation. Using ATF mixed with engine oil is the best way to go if there is no physical damage to the VVT units or other timing components.
Another area that seems to get little attention is the screen on the oil pickup tube located in the sump. Removing the sump on the 3.0 litre unit requires also removing the front crossmember, but that is certainly less complex than removing the motor once it has failed. If the screen is blocked by contamination, the oil pump will not be able to supply sufficient oil at pressure to the VVT unit.
Old Jun 17, 2012 | 08:57 AM
  #32
Sal16's Avatar
Thanks everyone for all the info. Yes the re-flash failed to eliminate the code so the problem must be glogging top end or screen; or wear. Doing the 5-20w with AFT and hope I don't have to drop sump. Will update. Thank you all for sticking with me (sticking may not be the right word, ha). Hope I can return favor in the future.
bamforp
Aug 14, 2024 05:36 PM
99xk8guy
May 28, 2024 09:36 PM
jerry_hoback
XJ40 ( XJ81 )
Sep 13, 2015 07:48 PM
mhamilton
Sep 12, 2015 03:21 PM
giandanielxk8
Sep 6, 2015 07:21 PM
