Overheated & Multiple CEL codes - P0171 P0172 P0174 P0175
Hello again to everyone,
2006 Jaguar S-type 125000 , 3.0L V6 - love this vehicle.
CEL light have been on for a few days, when scanned it shows 8 codes P0171 P0172 P0174 P0175 & the same codes with a P after it, P0171 P ,P0172 P ,P0174 P, P0175 P im not sure what the extra P is but I am using some cheapo odb scanner I got on amazon so possibly its a bug?
In any case yesterday driving home the car stalled/turned off at a red light (dash gauge was showing the engine in normal temperature) ... I let the car sit for 30min, added some water as the reservoir looked empty, when adding 1 gallon I heard bubbling and saw steam. No water leaked out over the next 10minutes. Car fired back up and drove it home, CEL is on but car felt completely normal.
I am going to read a bunch of forum posts on the codes above, I just was not sure if all 4 codes together means something different. On other posts I do see members saying check vacuum leaks and the such but those posts only mention the 2 codes and the car was not shutting off.
Not driving the vehicle until this is resolved. I was thinking to check/change the MAF , but not certain how to check if its good or bad ??
Any help / guidance is much appreciated - LOVE this forum and appreciate you members very much for the help in the past!
Have you got a copy of the JTIS?
make yourself a diy diagnostic smoker (google a you tube vid) as it sounds like you have a air leak in the vacuum pipes.
I thought you had corrected the water leak problem last year.
Check your oil to see if there is any sign of water oil emulsion because it does not sound good.
Thanks for the advice.
Yes I have the JTIS. Will look into a DIY smoker tonight. I did not notice any foam / milky stuff in the oil cap/dipstick but will check more into that as well and update, blown head gasket is scary.
Water leak was corrected ... not sure why the reservoir was empty yesterday. Will have to recheck that. Do you think there may be 2 separate issues going on?
Step back from the ledge! Don't jump!
The codes are most likely caused by a vacuum leak(s). The engine probably stalled because of that. Find and fix the vacuum leaks. We can walk you through the details. Then drive the car. Smile cuz the S-Type is a bitching car in a world full of Kias.
Other than the low coolant, was there any evidence of actual overheating? When was the last time you had checked the coolant level? It could have been low for some time and gone unnoticed until you found it while in the throes of another problem and convinced yourself it meant something worse. The steaming/bubbling was probably perfectly normal as the cold water met the remaining hot coolant. Look for milkiness on the dipstick. Run a cooling system pressure test to rule out internal leaks. But so far, all you know for certain is that the coolant was low. The temp gauge was normal. No mention of any abnormal noises, either. Top off the coolant and keep an eye on it. But from what you've described, nothing fits an actual overheat.
The codes are most likely caused by a vacuum leak(s). The engine probably stalled because of that. Find lajnd fix the vacuum leaks. We can wa jlk you throughh the details. Then drive the car. Smile cuz the S-Type Ishmael a bitching car in a world full of
Other than the low coolant, was there any evidhence of actual overheating? When was the last time you had checked the coolant level? It could have been low for some time and gone unnoticed until you found it while in the throes of another problem and convinced yourself it meant something worse. The steaming/bubbling was probably perfectly normal as the cold water met the remaining hot coolant. Look for milkiness on the dipstick. Run a cooling system pressure test to rule out internal leaks. But so far, all you know for certain is that the coolant was low. The temp gauge was normal. No mention of any abnormal noises, either. Top off the coolant and keep an eye on it. But from what you've described, nothing fits an actual overheat.
Never gonna jump... never say die! Lmao thanks for that reply! Amen to that Kia comment!!
Ok so I found a loose connector on one of the lower hoses I guess someone replaced them before as it's sconnected with one of those metal screw to tighten bands vs the harder pinch to open bands. In any case, filled it up with distilled water will watch the water if it holds I'll flush empty that refill with dexcool. Pressure test on reservoir held @ 15psi for 5min so I'm thinking that's fine.
No signs of foam/milkiness on dipstick or cap- oil feels and looks normal. Car started back up fine engine coolant light went away, CEL still on , will have to work on that vacuum leak next. Looking up the smoker thing now and research vacuum leaks on this forum.
OBD live data can show you the LTFTs, which should be near zero at idle and not change much if you rev it to about 2500. The likes of an elm327 can do live data.
No problem
Just keep your Cuban cigars for when you are finished.
I almost lit up one of my new cigars last night while checking the hoses lol I decided to wait until this vacuum thing is handled! funny you mentioned that
Live data can normally show with almost no cost and in effect zero effort and time that you do or do not have a leak. If you don't then smoke test is pointless.
You have the V-6 which has a list of known problems starting with the IMT valves on the intake. Also a vacuum elbow that is known to rot and leak. Note both of these are vacuum leaks and will give the codes you have.
Have you done any of that repair? All the V-6 engines will get these failure eventually but if you DIY that are really not that expensive to fix. We have some very good repair guides for the V-6 guys as these are very common failures.
Have you changed the plugs?
Have you serviced the transmission?
Thank you all for the advice. So after a mishap , i was able to get the live data. See the photos but from what I looked up anything above 9 and below -9 is bad .. looks like im way past that lol
Go to the fifth post here https://www.jaguarforums.com/forum/s-type-s-type-r-supercharged-v8-x200-15/cant-seem-figure-out-misfires-codes-181227/#post1675852
Sorry for the lack of updates, work has been really busy. I put the jag on the back burner until this weekend - i will do some more research and post updates & further questions once I have something.
