P0306 Cylinder 6 missfire
Old Aug 14, 2015 | 05:05 PM
Rex's Avatar
Rex
Default P0306 Cylinder 6 missfire
Would it be reasonable to assume plug coil? It is 2000 4.0 Sport. Which cylinder is 6?
Old Aug 14, 2015 | 05:09 PM
Probably. Is it an 8 or a 6?
Old Aug 14, 2015 | 05:19 PM
Rex's Avatar
Rex
V8
Old Aug 14, 2015 | 05:28 PM
OK
File Type: pdf
Old Aug 14, 2015 | 06:17 PM
Rex's Avatar
Rex
Perfect. Thank you. Just bought coil and will fix when engine cools. Great car!
Old Aug 14, 2015 | 06:40 PM
abonano's Avatar
Drivers side - 2nd coil from front of engine
Old Aug 18, 2015 | 11:21 AM
tonykart's Avatar
I have a 2002 4.0 and I did not do well chasing just one coil at a time. I am now of the school that if you are getting a coil miss (your first or second?)it is best to replace all 8 coils and plugs, otherwise you will replace them one a at time in 2000 mile (or so?) increments.
Old Aug 18, 2015 | 05:08 PM
tbird6's Avatar
He is right. We have seen many people start with one coil code and only replace that one. Then get another code within a few months.
Your car is now over 15 years old and ALL of the coils and plugs need to be changed.
Please consider changing the cam cover gaskets as well. This is mandatory if oil/water is found in the plug wells.
It's much easier and quicker to do all of this as one repair job.
PhilXJ6
Jan 3, 2016 08:55 PM
Delta66
Oct 4, 2015 05:40 PM
sandmann62
Oct 1, 2015 09:31 AM
baskervillema
Oct 1, 2015 01:59 AM
