P0446, 2005, 3.0
Old Sep 9, 2024 | 11:46 AM
joycesjag's Avatar
Default P0446, 2005, 3.0
Jon89's beloved S Type has become the MagJag some years ago. I was driving home yesterday with Todd, Maggie's father when Maggie video phoned. S Type was a quarter tank full, Maggie attempted 2 pumps, when fueling gas would rush out of the fill port. A 3rd pump at different has station worked fine.
I know when GM trucks are "topped off" after the first full kick off, the carbon canister gums up causing this refuel problem.
I have searched here and of course Google, to no avail. I am turning the experts here for ideas.
I am not to concerned with the P0327.
Old Sep 9, 2024 | 01:29 PM
scottjh9's Avatar
I am just speaking of prior exp with the evap code in general. I have had that code on 2 gm vehicles. Replaced the vent and purge valve and cured it. The k sensor code is one i have never seen just go away. Usually needs sensor replacement or broken wire. If you have access to a scope you can rap on the block or near the sensor and see how it reacts on the scope
Old Sep 9, 2024 | 03:49 PM
motorcarman's Avatar
P0446
Possible Causes:
Fuel tank / EVAP canister atmospheric port: restricted, blocked
EVAP canister close valve failure (stuck closed)
DTC = EVAP canister close valve malfunction
Jaguar is calling the XR828437 a Purge Control Valve or Solenoid. I am guessing it is the CCV?
I see no other control valves in the EVAP circuit.
I would pull the hose off the valve and try to fill the tank.
Old Oct 1, 2024 | 11:39 AM
joycesjag's Avatar
Ok a little follow up. There are 2 different types of vent canisters that were used. One is readily available at dealer and big box stores the other obsolete, only replacement is from a wrecker. Magjag needed the obsolete one.
These canisters are hidden above the rear axle/pumkin. They are not DIY friendly!! If you need to replace I strongly suggest cutting sheet metal in the trunk to access.
Since Todds is obsolete we took a hammer and worked over the canister as much as we could access. So far Maggie has not had an issue of gas pump shutting off immediately when attempting to fill gas tank.
christopher cooper
Jun 15, 2024 02:17 PM
bcprice36
Oct 16, 2023 04:14 PM
David Matt
General Tech Help
Jul 30, 2023 03:12 PM
reznik6044
Jul 10, 2018 09:13 AM
jakesdad
Jan 27, 2018 10:23 AM
