P0741 code transmission fault
Old May 1, 2012 | 07:30 PM
hifipm's Avatar
Default P0741 code transmission fault
I had a 'transmission fault' warning while on the highway last night ( at about 120kph) and then the check engine light came on. The transmission warning went off after I stopped and restarted but engine light stayed on. Purchased a OBD2 code reader -P0741 came up.
I had the transmission rebuilt (inc. new torque converter) a year and a half ago but it was never quite perfect - a jumpy sift from 1-2 and 2-3 it was violent before rebuild between 1-2 the transmission shop could not reprogramm properly and the dealer tried about a year later when I had it in.
Could this lack of proper reflashing of ECM/TCM cause both the shift problem and now the P0741 problems?
03 str 105k miles
Old May 2, 2012 | 03:30 AM
JagV8's Avatar
Car details? (See below)
Old May 2, 2012 | 02:27 PM
searanch's Avatar
It's your torque converter throwing the P0741 code. The gearbox fault code will go away after you shut the engine down. If you don't clear it after the third time it throws the code it will go into restricted mode. Don't leave home without your OBD2 reader or you may be walking.
It's usually the 5/6 shift which causes the P0741 initially as the clutch surface is coming apart. You can get it rebuilt but ya need to find someone who is familiar with the 6hp26 tranny and especially if it's an STR as they use different surfaces than standard.
Make sure that whoever does the work uses a Jaguar front seal on the transmission and not the generic 6hp26 seal. The generic will leak.
This advice is worth exactly what ya paid for it...
Old May 2, 2012 | 05:37 PM
hifipm's Avatar
Thanks for the reply- transmission shop believes it is the solenoid stuck open and are removing the pan next week to investigate- I' m just going to search the forum for solenoid issues-thanks Paul
Old May 2, 2012 | 07:46 PM
clubairth1's Avatar
Community Influencer
The TQ is a known problem but the solenoids are not. If you paid for TQ with the rebuild I think they will need to get you a new one.
Was it new or did they put a rebuilt unit in?
Any chance that they maybe did not replace the TQ but said they did?
From your description I sure hope it's still in warranty!!
Be careful about solenoids because that was a problem with the early Ford 5 speed transmission used in the 1999-2002 cars. Not a problem with the 6 speed ZF. They have all their very own problems!
Old May 2, 2012 | 08:18 PM
hifipm's Avatar
Default Solenoids
It was a new TQ, I have no reason to believe otherwise but I did read in another post that it should have a Jaguar sourced small o ring as the generics won't last- I doubt mine was from the dealer so...I kind of hope it's the solenoids or wiring. The transmission is no worse than before this happened- it sifts through all gears but can be a bit jumpy between 1-2 and 2-3 just as it has always been-seems to change ever time I drive it but I could be imaging it at this point!!
Old May 9, 2012 | 05:50 PM
hifipm's Avatar
Default Po741 solenoid
Just thought I would update my own post with fresh info- originally I posted with a P0741 code and the transmission shop looked at it today and replaced a solenoid- seems to be working fine, with no codes or warnings- i'll have a chance to get it out on the highway this weekend and really check it out!
Thanks all who replied.
Old May 13, 2012 | 12:22 PM
hifipm's Avatar
Default not solved
Unfortunately the same problems back after a couple of days of (aggressive) city driving- P0741 so back to the transmission shop monday- I have a feeling they are over there heads, without access to Jaguar diagnostic equipment but we will see.
Old May 13, 2012 | 12:40 PM
clubairth1's Avatar
Thanks for the update.
As I said the ZF is not known for solenoid problems so that was suspicious from the start.
But your problems don't seem to be one of the common ones either?? I hope you can get it fixed and let the rest of us know what is was?
Old May 13, 2012 | 01:14 PM
hifipm's Avatar
Default tcm-valve body
After looking through the ZF manual ( pdf from this site) it seems that I need to replace the TCM/valve body- anyone know how much this part might cost??
Old May 13, 2012 | 01:19 PM
motorcarman's Avatar
When the 6HP26 gearbox was introduced we had a TSB for the P0741 fault.
Here is the old bulletin for info.
bob gauff
File Type: pdf
Old May 13, 2012 | 01:32 PM
JagV8's Avatar
Newer version of the TSB
File Type: pdf
Old May 18, 2012 | 03:51 PM
hifipm's Avatar
Default New Torque Converter
Final (I hope!!) resolution with new torque converter- transmission shop covered the labour (they did original rebuild 2yrs ago) I just picked it up in rush hour so not much driving time but seems good-thanks to all who helped.
Paul
They spotted lots of exhaust rot so on to my next project!!
Old May 18, 2012 | 04:35 PM
JagV8's Avatar
Good news on the TC!
On the exhaust, that's unusual. I understand it's a special passivated metal so that it lasts. You'll see how rare this is if you try Search to find others who've had the problem.
Old May 19, 2012 | 10:06 AM
searanch's Avatar
Paul
Slaps forehead...
tomsjag
Jun 10, 2023 10:02 AM
philwarner
25
Jun 26, 2021 05:43 AM
cissdm
May 3, 2016 06:02 AM
tonyforman
Sep 10, 2015 07:23 PM
TexasCat
Sep 8, 2015 04:36 AM
