P1108 Map/Baro code need help
Old Nov 1, 2014 | 07:27 AM
smfordtech's Avatar
Default P1108 Map/Baro code need help
I have a 2004 S Type with a 3.0 liter v6.I have an intermit P1108.I clear code and drive car every thing runs fine until I shut car off and let sit about 10 mins and restart then the MIL comes back on.I have replace the MAF sensor and still have the same concern.I have checked pins and all look good.I have 4.9v vref and 12v pwr.Need some advice what else could be wrong?
Last edited by GGG; Nov 1, 2014 at 01:37 PM. Reason: change model and year to bold type
Old Nov 1, 2014 | 01:36 PM
I've moved your question from General Tech Help to S-Type forum. Members here with the same model will be able to help.
Old Nov 2, 2014 | 08:24 AM
JagV8's Avatar
Get JTIS and/or codes PDF and then look up the code - it's not MAF but MAP related.
Old Nov 4, 2014 | 08:16 AM
smfordtech's Avatar
I have been a Senior Master Tech for Ford 32 yrs retired,this looks just like a Lincoln LS 3.0 liter under the hood.The Map sensor is built into the MAF sensor on everything I have read.Am I wrong?
Old Nov 4, 2014 | 10:17 AM
joycesjag's Avatar
The MAP sensor is located near the firewall, rear of the plenum, just to the right of the upper IMT valve, if looking at the motor from the front of the vehicle.
Best to check obvious first. Not to many MAP sensor problems reported here over the years.
Old Nov 5, 2014 | 05:24 PM
smfordtech's Avatar
I have a sensor that is in the back of upper intake at the center,then 2 intake controls on back.This is diff then Lincoln set up.P1108 is a circuit code from Baro to Map.It's funny I can clear code and drive all day if I don't shut motor off .If I shut off let sit 10 mins and restart light will come on CRAZY !!!!!!!!
Old Nov 5, 2014 | 05:54 PM
JagV8's Avatar
No, it's not. Trying to over-think exact details of a PCM's software for when it flags a particular code, now that's crazy.
Old Nov 5, 2014 | 07:48 PM
joycesjag's Avatar
Ok, here is the best picture I have to show you the MAP sensor. You are correct (as I mentioned), the sensor is located on the back of the "upper intake" which we here call the plenum, located next to the "intake controls" which we know them as IMT Tuning Valves. Best to make sure those IMT's are not leaking oil (follow the link under the picture).
Sorry I do not know anything about the Lincoln "set up" as we own a Jaguar. I have never seen what a Lincoln 3.0 looks like.
MAP Sensor:
Here is another view, with the cowl cover (plastic cover under the wiper arms) removed, and looking down:
IMT O-ring leak check link:
https://www.jaguarforums.com/forum/s...ck-pics-49214/
Attached Thumbnails P1108 Map/Baro code need help-imt-oring-map-sensor.jpg   P1108 Map/Baro code need help-map-sensor-e.jpg
Last edited by joycesjag; Nov 5, 2014 at 08:03 PM. Reason: found another picture to add
philwarner
Oct 4, 2024 01:37 PM
Shawn Svacha
Feb 6, 2022 04:53 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
JCam
Oct 23, 2016 08:27 PM
