P1578 code and rough idle
Had the check engine light come and it came out to be p1578 which deals with the throttle body. I dont think thats the problem because it has a really rough idle and it doesn't sound like all 8 cylinders are firing. Anyone have this problem?
No-one has ever posted that. Also, I cannot find that code as valid for Jaguar cars.
What tool has given you the code and is there any chance that it's been posted incorrectly or communicated incorrectly?
I would not assume it relates to the TB.
Many times a dubious code is caused by a failing battery or poor power/ground.
You have the dreaded 4.0L V-8.
Do you know about the timing tensioners and have they been replaced?
It sounds very much like you have jumped time. I hope you are not too late to save the engine.
Im sorry I did type it wrong, its P1587. I checked the battery and its good but the alternator is not charging well though
I dont know what state they are in but I'm pretty sure they haven't been replaced. If that's the case I hope its not too late too, how would I know?
Sorry but the software for this forum is absolutely terrible and now has been changed to be almost unusable!
I tried for 30 minutes to correctly insert 4 pictures in my answer but it is all screwed up. You can only dump pictures with no control. Terrible software again. I am on several car forums and this one always gives the most problems and is the most difficult to post to and most often has errors when loading.
But you can pull a cam cover off and look at the tensioner. It was bright white plastic when new. It will now be orange/red plastic with cracks. The new updated ones are mostly metal and will hold up.
I have the pictures attached but I could not insert them so they made sense!
