Park brake fault
Old Oct 8, 2021 | 09:14 AM
Paula Vecchiarelli's Avatar
Default Park brake fault
Can somebody please tell me what a park brake fault is? Not only is that on but my brake light is flashing and my ABS light is also on. Please help my fellow Jaguar enthusiast.TIA
2003 Jaguar S type 3.0
Old Oct 8, 2021 | 09:27 AM
S-Type Owner's Avatar
It is difficult to make recommendations not knowing your DIY skill level, but you have indicated two of the three usual suspects that indicate a low battery voltage situation. Your appear to be in Tucson, which certainly exposes your battery to extremes of temperature. Do you have a multimeter that you can use to test the battery voltage and report back to us? If not, most auto parts stores will test your battery at no charge.
Old Oct 8, 2021 | 10:28 AM
YYZJAGUAR's Avatar
Could be a bad battery..also the Park Brake Module Actuator could be faulty...Do you hear the park brake motor when park brake is engaged?.... The Park Brake Module Actuator mounts to the rear subframe...You need to to take to a competent mechanic..You need a hoist to complete the job properly.
Old Oct 8, 2021 | 10:43 AM
kr98664's Avatar
Me thinks you're not the first person to have this slew of faults:
https://www.jaguarforums.com/forum/s...attery-193787/
Old Oct 8, 2021 | 07:38 PM
My battery was dead this morning, jumped it to get to work. Came out of a 9 hour day and it was dead again. Went to AutoZone and had the battery tested. It was bad. Replaced it, but now what I need to know is how long does it take the computer to rest those lights that are on my dash (the ones listed in my beginning post)?
Old Oct 9, 2021 | 01:56 AM
JagV8's Avatar
Normally immediately on driving (& you resetting the EPB) but read the codes.
Old Oct 9, 2021 | 09:15 AM
kr98664's Avatar
Hi Paula,
These messages should clear themselves right away once the underlying cause is corrected. You may have fallen into that gray zone where you've fixed A fault, but not necessarily THE fault. Some things to consider:
For the fault messages you're seeing, the most common cause is low prestart voltage. There are other possibilities (bad actuator, wheel speed sensor, etc.), but I'd concentrate on low prestart voltage first because it is easy to rule out, and you've already mentioned a failed/discharged battery.
Your new battery may not have been fully charged at the time of purchase. Few are. Don't rely on the alternator to have charged it. Hook up an automatic charger overnight and see if that helps. This is a very important prerequisite for any electrical troubleshooting, so please don't skip this important step.
Your charging system may not be up to snuff, and may have contributed to the demise of the battery. After charging your new battery (Gee, he seems obsessed with that...), test the alternator output. Connect a voltmeter to the battery terminals and start the engine. You should see around 14.5v for the first few minutes, tapering off around 13.5 after a bit.
Further down the troubleshooting tree is to check for an electrical drain running down the battery overnight. This is why I keep harping to charge the battery first (There he goes again, he must be a lot of fun at parties...) and see if that helps. If so, you'll need to figure out why the battery is running down when left to its own devices. This could either be an external drain or a bad battery. Since the battery is new, it would be rare for it to have failed so quickly, but that's not impossible. The more likely cause is an external drain.
Old Oct 9, 2021 | 09:24 AM
Smile
OK, so the park brake fault light is off, my brake light vis off & the ABS light is off. I will check the charging system with a voltmeter (my husband is an electrician) and double check the voltage. I really appreciate this forum so much, my fellow enthusiasts never let me down. Thanks again, I hope you all have a wonderful day!!
Old Oct 9, 2021 | 09:39 AM
kr98664's Avatar
Thanks, but I had other plans...
Old Oct 12, 2021 | 08:35 AM
kr98664's Avatar
Well? The suspense is killing me...
Old Oct 16, 2021 | 11:54 AM
Freedman's Avatar
Default S type 2.7D
I have had a 2004 S Type since 2006.
I often had problems with the electronic handbrake, not engaging or not releasing.
All the problems ceased when I finally replaced the battery, which was the original from Jaguar, after14 Years.
So I suggest get a new battery!
Old Oct 17, 2021 | 09:11 AM
clubairth1's Avatar
Community Influencer
Hey with 14 years on that battery you REALLY got your money's worth!! Must be a record as I have gotten 8 years so far out of my factory battery and expect it to fail anytime due to age.
Old Feb 15, 2023 | 12:20 PM
tek_uk's Avatar
*ignore - posted on wrong thread *
Last edited by tek_uk; Feb 15, 2023 at 01:37 PM. Reason: posted on wrong thread by mistake
turkay
Mar 29, 2021 09:10 AM
knotslanding1
Nov 19, 2014 07:32 PM
anatwick
Sep 11, 2014 09:09 PM
Walter Brooks
19
Dec 29, 2013 08:38 AM
climberman
Dec 16, 2010 12:41 PM
