Park break failuer in S type 2005
Old Feb 11, 2013 | 10:02 AM
Iyadabdulsamad's Avatar
Default Park break failuer in S type 2005
Hi. I got 2005 S type. I have a proplem with the park break it shows on the screen Can Not Apply Park Break & there is peep sound continuisly when i drive the car & when i stop the peep is gone. Does any one face this this proplem before can help? How it can be solved because it took it to the wooekshop & on computer chick every thing is woorking & no fault showing. Thanks all
Old Feb 11, 2013 | 10:13 AM
totalimmortal363's Avatar
How's your battery?
Old Feb 11, 2013 | 10:50 AM
It is good. I had it tested & recharged. It is giving the maximum power
Old Feb 11, 2013 | 10:56 AM
JagV8's Avatar
Have a good try using Search - better, use Advanced Search so you can choose just this forum - then do some reading and hope it IS the battery because you're not going to like the look of it being the EPB motor or module.
How long and how did you recharge it? What's its date code?
Old Feb 11, 2013 | 11:15 AM
Yes actually i am afraid of EPB motor life ended because here in Dubai a second hand one cost over 300 dollars & no one is expert in it & the dealer is over costly. I,ll try as you said & hope i find out a solution. Thanks for your time
Old Feb 11, 2013 | 11:18 AM
& i just fixed new battery before 3 months only. The date is 9 / 2012. That,s why i am shore it is not the battery even i put it on power charger for like 4 hours. Thank you again
Old Feb 11, 2013 | 11:49 AM
JagV8's Avatar
4 hours is not long, in case it is a bit flat such as from a drain you don't realise you have.
Old Feb 11, 2013 | 12:51 PM
i did for 4 hours only because the charger gauge indicate it is full & no more charging
Old Feb 11, 2013 | 02:28 PM
JagV8's Avatar
Just possibly a Mogoose JLR (fairly cheap) could reset / exercise the EPB but otherwise you might try powering the motor direct (disconnect module - on my car it's behind trim above battery - and the thick wires are for the motor; use a fairly hefty inline fuse I suggest).
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
zecretw
Aug 31, 2015 04:02 PM
DeaconHull
Aug 28, 2015 05:26 PM
divingmom
Aug 25, 2015 07:54 PM
