Parking aid beep stays on while backing up...
Old Feb 19, 2014 | 11:58 AM
Bkny85's Avatar
Default Parking aid beep stays on while backing up...
Is this a common issue? When I hit reverse the parking aid beeps the entire time with a LONG BEEP until I put it back into drive. Does not do it everytime. Any ideas?
Old Feb 19, 2014 | 12:01 PM
2000JagLvr's Avatar
Check to see if you have some snow/ice build up on any of the sensors. If not, you probably have bad or failing sensor.
You're not the first to have this problem. Try doing a search for bad parking aids or sensors.
Old Feb 19, 2014 | 01:35 PM
mike213735's Avatar
Hi,
Could it be a warning that one of your sensors is duff.
Try putting the car in reverse and then put your ear right up to the sensors in turn. You should hear a quiet, but audible clicking if they're working OK.
Mike.
Old Feb 19, 2014 | 04:07 PM
JagV8's Avatar
Yes, that's part of what the existing threads point out.
Old Feb 19, 2014 | 04:55 PM
tbird6's Avatar
Just do it with the engine off! Be sure and block the wheels so the car does not roll.
It's much easier to hear the clicks and you can do it by yourself.
Old Feb 19, 2014 | 09:43 PM
motorcarman's Avatar
The reverse parking aid module is on a network and will log DTCs.
You can access the module for interrogation.
It probably is one of the sensors.
bob gauff
99xk8guy
Sep 29, 2025 10:51 PM
Jpav27
Jul 31, 2022 06:43 AM
Rlover
Mar 30, 2016 10:04 PM
tberg
Sep 7, 2015 07:32 AM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
