Pinion Seal Leak?
Old Mar 20, 2013 | 08:02 PM
okStypeR's Avatar
Default Pinion Seal Leak?
Back from 120 mile road trip, after a wash i decided to look under the car. Noticed oil splatters on the exhaust pipe and oil dripping from the rear diff. Looks like it is seeping out of the driver side axel where the axel meet the differential. My guess is the pinion seal but not 100% sure. Can anyone determine the leak from the pictures? Any info would be appreciated..only had the car 1 month. It has 77,000 miles.
Attached Thumbnails Pinion Seal Leak?-20130320_4.jpg   Pinion Seal Leak?-20130320_2.jpg
Old Mar 20, 2013 | 08:14 PM
clubairth1's Avatar
Community Influencer
Never seen it before and have not heard of it but you are right! It's the axle shaft seal. Many cars with more miles and no problem so lets hope it's just one of those things.
Old Mar 20, 2013 | 08:55 PM
QuartzSTypeR's Avatar
Looks like the output shaft seal. The pinion seal is where the driveshaft goes into the diff.
Old Mar 20, 2013 | 09:11 PM
okStypeR's Avatar
Ok, i was looking at a parts diagram, thanks for the correction. I know a mechanic and i will ask him tomorrow what it would take to fix this in my garage.
Old Mar 20, 2013 | 09:20 PM
Its not too bad, pull the axle and the seal is exposed. Pop it off (likely won't come off easily), clean the area up, put the new seal on and make sure the diff fluid is full.
Old Mar 21, 2013 | 07:32 PM
clubairth1's Avatar
Have you had a leak in your STR?
Old Mar 22, 2013 | 12:11 AM
Nope, but I've replaced many output shaft seals on various vehicles.
okStypeR, I would also be sure to make sure the breather tube isn't clogged. If it is, it can lead to more leaks as the pressure buildup needs to release somewhere. Maybe your leak is actually from the breather tube and you can get off easy?
Old Mar 22, 2013 | 01:24 AM
plums's Avatar
Clear the breather first, top off and see if the leak goes away.
Clearing the breather has "cured" many seal leaks on JF.
Old Mar 22, 2013 | 08:59 AM
okStypeR's Avatar
Thanks for the input guys, you are right, I should start off with the easy fix first and move from there. I will put it back up on the ramps and take a look. Assume there is a small valve with a tube attached at the topof the diff? I did buy 2 axle shaft seals from Gaudin Jaguar yesterday, only 9.70 each. I bought 2 in case i mess one up during the install. Waiting of some rear diff fluid too. I will keep you posted on the progress, and if it comes to replacing the axle shaft, i will attempt to document the process with pictures (not making promises) once the hands get greasy the last thing i want to pick up is my camera.
Old Mar 22, 2013 | 11:38 AM
tbird6's Avatar
Do you know where the vent is? It's not that obvious and a lot of cars don't have a hose attached to it so it's kind of invisible.
We had a pretty in depth discussion with pictures and diagrams here:
https://www.jaguarforums.com/forum/s...ear-end-74577/
Old Mar 27, 2013 | 07:45 PM
okStypeR's Avatar
Got under the car again today and more fluid has leaked out from the output shaft seal so i will be replacing it next week. As far as breather valve...i guess i will have to get a small mirror and look around for the breather valve. Even if it was clogged I'm not sure i could fix it! Very tight up there...has anyone on here done this before? Glad this is not my daily driver...
Old Apr 14, 2013 | 08:43 AM
okStypeR's Avatar
Just wanted to update you guys on the output shaft seal repair. I managed to remove the rotor, calipers, sway bar links, etc in order to remove the axle and replace the output shaft seal. Once everything is free, the drive shaft will not release from the rear diff., there is a keeper pin or c clamp holding the drive shaft in place. At this point i did not want to go any further with the drive shaft removal. I put it all back together and with parts in hand, drove to Jaguar of Tulsa and let them repair the car. Using my own parts (2 output shaft seals) they replaced both seals for $316.00. I was expecting more so it was a nice suprise.
Old Apr 14, 2013 | 10:30 AM
clubairth1's Avatar
You have to "pop" the axles out just like on a FWD car.
Here is the slide hammer tool you need. I think you can get a free loaner at AutoZone.
Old Apr 15, 2013 | 09:55 AM
okStypeR's Avatar
thanks for the advice, already fixed and i hope it will be for the last time.
aholbro1
Dec 29, 2024 06:46 PM
sogood
Sep 15, 2015 07:35 AM
SeanU
Sep 14, 2015 04:31 PM
MHF25
Sep 13, 2015 05:24 AM
d a
Sep 3, 2015 02:34 AM
