Please help with fuel delivery issue-03 STR
Old Sep 9, 2013 | 10:48 AM
chrisgsemail's Avatar
Unhappy Please help with fuel delivery issue-03 STR
I bought a 03 str that was hit on the rear passenger side wheel. Has not started since accident. I've spent many hours and have read countless threads I cant seam to find the issue.
here is what i've tried or know so far:
118,000 miles
no fuel at schrader valve
replaced fuel filter
inertia button pressed and tested for power
Brand new battery installed
10 gallons of fresh gas in tank
tested power to fuel pump fuse
relay was tested
replaced driver control module-
PATS working not flashing code
codes prior to battery replacement
p0400
p1646
1165
p1000
c1165
after
p1000 battery replacement
when key is turned on I can hear a pump turn on. While key is on I can hear some kind of sound under dash-kinda sounds like something bumping around from vacuum- not sure- I can take a video if someone thinks that may help to diagnose.
Ive had 3 so called Jaguar mechanics out to try to diagnose. None of them had a conclusive answer. I cant afford to guess whats not working and just throw money at this issue by replacing parts for no reason.
Ive found plenty info on the S type bu not the str which from what I have read has a different fuel system.
Can someone please point me in the right direction.
Old Sep 9, 2013 | 11:24 AM
police666's Avatar
First of all download jtis from this site. It's the jaguar workshop manual.
Are you getting fuel as far as the filter?
Old Sep 9, 2013 | 01:19 PM
tbird6's Avatar
In your other thread you said the pump did not sound healthy?
It's possible for the pump to run but not push enough fuel up to the test port.
As was suggested above remove the fuel filter and see if any fuel comes out the input to the filter.
Here is one from left field. Years ago I bought a T-Bird (Which I still have 41 years later!!) and had all kinds of problems getting fuel to the carb. I finally dropped the tank and had a look. Someone had stuffed a piece of a neoprene wetsuit in the tank. I think what happened was they did not have a gas cap and stuffed the fuel neck with this rubber stuff as a temporary fix. As you can imagine the car would start then stop or start and run for awhile then die with no fuel in the carb.
With as much time and effort you have into this maybe it's time to drop the tank and make sure it's not got something blocking the pump inlets or maybe you have a collapsed fuel sock??
Of course our cars are well designed and I think you could do a pretty good check by pulling the back seat bottom and then both fuel pump covers. Just be aware you can damage these top tank seals so be careful.
Here are the access ports. Note this is an LS but the S Type is the same.
Attached Thumbnails Please help with fuel delivery issue-03 STR-lincoln-ls-fuel-pump-access-holes.jpg
Old Sep 9, 2013 | 01:58 PM
tbird6's Avatar
Here is a picture of one of the STR fuel pumps. Check that the hoses don't have any holes as this will allow the pump to suck air and not liquid. Maybe something is unhooked??
I can't remember if you got the JTIS or not but you really need it.
Attached Thumbnails Please help with fuel delivery issue-03 STR-2003-s-type-r-engine-fuel-jet-pump1.jpg
Old Sep 10, 2013 | 07:09 AM
JagV8's Avatar
Wow - great pics!
It does sound like a pump or hose problem. The dash noise you can safely ignore (it's HVAC-related).
Old Sep 10, 2013 | 08:35 AM
Thanks guys,
I appreciate the responses. No gas pressure at the filter. Before I pull the tank I will remove the 2 pumps, inspect and test. Im going to do that in a couple hours, Ill report back this afternoon
Old Sep 10, 2013 | 09:42 AM
police666's Avatar
Ok, no gas at the filter, sounds like pump problems or a pipe blockage.
clubairth1
30
Sep 3, 2025 04:38 PM
njburlington
Sep 22, 2020 07:03 AM
JWheeler
Nov 22, 2019 08:28 AM
Dimitrigregorio
17
Sep 5, 2019 03:47 AM
njburlington
Sep 24, 2015 08:40 PM
