Please help with tps problem
Old Apr 11, 2014 | 05:34 PM
worker91's Avatar
Default Please help with tps problem
Hey Guys, so recently my car has been having some trouble. While your driving or parked, the car will idle to 1500 RPM and only accelerate to 3000 RPM then it turns on a red light and says the following messages: Engine systems fault, dsc not available, cruise control not available, and some other stuff. I put the scanner on and it gives me code P2135 Throttle/ Pedal Position Sensor/ Switch A/B Voltage correlation. Also it wont go more than 20MPH and when you turn it off it stutters off. Other problems currently happening, when climate control is on low it only blows heat. No matter what i do it only blows heat. I already changed the DCCV and that didnt help. Hope you guys can help, all i wanna do now is get rid of it. BTW its a 05 S-Type 3.0 AT with approximately 35,000 miles...
Old Apr 11, 2014 | 06:00 PM
QuartzSTypeR's Avatar
You can try cleaning the throttle body and the connectors and reset the code. Chances are, however, that you will just have to bite the bullet and replace the throttle body.
Old Apr 11, 2014 | 06:28 PM
Mikey's Avatar
Plus the standard advice to change the battery.
Old Apr 11, 2014 | 07:26 PM
police666's Avatar
might be worth trying the pedal to the floor slowly 3 times with engine off
File Type: pdf
Old Apr 11, 2014 | 08:57 PM
worker91's Avatar
Ok thanks guys, I'll let you know how it goes tomorrow. I think ill go with changing the throttle body, do you guys know if it has to be reprogrammed?
Old Apr 12, 2014 | 01:01 AM
JagV8's Avatar
The other thing is to check fuel trims and is it running CL (see my sig).
Suppose you have a failing battery then a TB is horrifically expensive and would do nothing.
Or an air leak. Ditto.
Old Apr 12, 2014 | 08:42 AM
worker91's Avatar
The battery was replaced not so long ago and i had it tested and its good. Im gonna try the throttle body because I have a used Jaguar parts dealer near me so it wont be that expensive if not ill keep looking for possible causes.
Old Apr 12, 2014 | 01:34 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Read & do Police666's suggestion above (see attachment) first. It costs nothing but time and could solve your problem and save you mega$$$.
Old Apr 13, 2014 | 06:29 AM
fredd60's Avatar
Default running problems
A 2005 car with very low mileage should not be having throttle body problems.
The high idle speed and unable to rev beyond 3000rpm, combined with the other warnings like dsc and cruise, would indicate a bad connection somewhere.
You could disconnect the battery, then remove and replace every fuse and relay.
Check connections to TB, and to main computer.
Old Apr 13, 2014 | 11:56 AM
worker91's Avatar
Ok guys so I ended up changing the throttle body with one I got from a Jag Graveyard and it solved the problem. I still have the problem with the A/C though so if anyone has any ideas it would be much appreciated. Thanks to all of you guys that gave me ideas and suggestions, you guys are awesome and I feel great to part of this community of Jaguar owners.
Clamdigger
Sep 12, 2015 03:43 PM
dragonfly777
Regional
Sep 8, 2015 01:39 PM
mcdutch
Sep 4, 2015 03:38 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
