Pre ignition noises
Old Jan 17, 2014 | 05:10 PM
BlackSTR07's Avatar
Default Pre ignition noises
Hi guys, I have a problem whit my 03 STR, so like a 10 minutes after start and running it, start to make some preignition noises. Always super unleaded fuel. Thank u
Old Jan 17, 2014 | 05:18 PM
tbird6's Avatar
Not any where close to enough information for even the most wild *** guess.
Take it to a shop.
Old Jan 17, 2014 | 05:25 PM
Mikey's Avatar
Pre-ignition is not related to fuel octane rating in any case.
Old Jan 17, 2014 | 05:30 PM
avt007's Avatar
Give us some more info, like when does it happen, full throttle,idle, mid range, cold, hot, etc. And how do you know it's pre ignition?
Old Jan 18, 2014 | 10:34 AM
BlackSTR07's Avatar
My car work better when the weather is cold, so my str running fine about 10 minutes, then begin to loss potency, making sounds "cascabelear" (spanish) like when the gas is in low octane (pre ignition), lower gas mileage. However is no overheated & no codes.
2 months ago had a burn head gasket, that was replaced tensioners & guides, no chains was replaced...
Old Jan 18, 2014 | 10:56 AM
Mikey's Avatar
You mean detonation (pinging) not pre-ignition.
Do you have any codes or warning lights?
Old Jan 18, 2014 | 12:16 PM
BlackSTR07's Avatar
I asked about that a mechanic... (no jaguar certified) He said think the motor no have enough antifreeze, that need to purge it, I did but nothing change. I thinking about radiator fan problem, because the second speed is not working (I think so), I'm put the A/C on maximum and no change to second speed.
Thank You guys for u interest
Old Jan 18, 2014 | 01:42 PM
BlackSTR07's Avatar
the sound is like when the fuel is low in octane... the sound is in the engine.
Old Jan 18, 2014 | 02:05 PM
BlackSTR07's Avatar
no lights, no codes at moment, just restricted performance, rattling and loss of power when accelerate and run for long time on freeway (like 20-30 minutes), no restricted performance when driving in city, just rattling and loss of power
Old Jan 18, 2014 | 02:06 PM
BlackSTR07's Avatar
I recently change the aux intercooler pump... I'm not sure if it's working properly
Old Jan 18, 2014 | 02:19 PM
Mikey's Avatar
Do you have an OBDII code reader?
Old Jan 18, 2014 | 07:23 PM
BlackSTR07's Avatar
no, but I was to autozone and no codes
Old Jan 18, 2014 | 07:27 PM
BlackSTR07's Avatar
I got 2 codes from bad HO2 and intake air leak, they was replaced and fixed codes gone... no codes
Old Jan 18, 2014 | 07:51 PM
BlackSTR07's Avatar
Can u recommend a obdii to buy... I will
JimC64
31
May 30, 2016 03:04 PM
Seth
Nov 1, 2015 12:17 PM
Tipptone
Oct 6, 2015 11:32 AM
Long Islander
Sep 27, 2015 03:45 PM
UKnFor-dluv-expat
Sep 26, 2015 08:40 PM
