Priming issue
Old Aug 26, 2018 | 10:31 AM
Daron Black's Avatar
Default Priming issue
I have a 2003 jaguar S-type 4.2 liter. It not priming right. Sometimes will prime and it will crack up and run and drive just fine till you turn it off then it stops priming it will stop priming anywhere between a few minutes or day till it works again.
Here is a list of what I have done so far to try and fix it.
1. Replace main and secondary fuel pumps
2. Placers all fuses with new ones
3. New fuel injectors
4. New o2 sensors
It out of my leugue now any help would be must helpful
Old Aug 26, 2018 | 10:43 AM
abonano's Avatar
4. New o2 sensors
Did you replace both pumps with new OEM units or used? I've also read about one of the check valves within the fuel pump system not working properly and crapping out.
Could be the case if you swapped in used fuel pump units.
Finally, if you swapped out the actual fuel pumps did you purchase the correct pump that puts out at least 4.7 BAR. Other pumps are identical but put out about 1 BAR less...
Old Aug 28, 2018 | 02:44 PM
Hello
yes both pumps are new oem
Old Aug 28, 2018 | 03:14 PM
S-Type Owner's Avatar
Daron: Looking at your list, one thing missing is the fuel filter. A filter full of debris or contaminants, often will cause intermittent blockages and symptoms similar to what you describe in your original post.
JR
Old Aug 28, 2018 | 06:17 PM
I'm sorry I forgot to add that it does have a new fuel filter
Old Aug 29, 2018 | 09:42 AM
I would like to add that when I put all this parts run it was working fine drove it down the road and got gas. Got home and it didn't start again it will not prime at all now and a code came up that is po430. I know that the o2 sensors and fuel pumps are together does the code mean I need a new cat convertor
TC Johnson
Aug 7, 2015 04:08 PM
BlackMac
Jul 3, 2014 04:16 AM
WinterJag
May 18, 2012 12:38 PM
SeldomJAG
Oct 11, 2011 12:21 PM
Jpetreeko
May 20, 2011 07:14 AM
