Radiator Options
Old Apr 20, 2012 | 11:50 AM
03Xtype's Avatar
Default Radiator Options
Are there any options better than OEM? I noticed on my 2005 the core is very thin.
Does Jaguar make their own rad or do they use an outside company to make them?
Old Apr 20, 2012 | 03:39 PM
03Xtype's Avatar
looks like visteon makes the radiators for jaguar. I found this sticker on the side of my radiator.
Old Apr 20, 2012 | 04:05 PM
Mikey's Avatar
Why do you want to re-engineer the cooling system?
Old Apr 20, 2012 | 05:41 PM
03Xtype's Avatar
My main objective is to find the same or higher quality part as the dealer item at a lower price. I'm only looking in to a direct fit part with no "re-engineer" mods required.
Old Apr 21, 2012 | 04:49 AM
JagV8's Avatar
They don't seem to fail often (hardly any posts here or UK forum about them) so may be OE only.
Old Apr 21, 2012 | 09:36 AM
Mikey's Avatar
Google found a bunch of supposed 'direct fit' rads ranging price from $95 up to $500. I think you're dreaming if you want to find a better, cheaper rad that fits as well as the OEM version. Good luck.
Old Apr 21, 2012 | 11:35 AM
Panthro's Avatar
Maybe the radiator for the XF/XFR might work as an upgrade. Don't know if the inlet & outlet are the same, but it could be around the same dimensions as your stock one. Since it's for a bigger engine that might be an option you can explore.
Old Apr 21, 2012 | 11:43 AM
03Xtype's Avatar
Old Apr 21, 2012 | 11:50 AM
03Xtype's Avatar
Visteon rads are priced very well, since they make the rads for jaguar I have a feeling they are restricted from selling this rad because of a deal with jag. Hopefully I can dig up a company that can sell me this part number so I can save a few hundred dollars and end up with the same jag part.
Has any one found a company that will sell this visteon rad?
Old Apr 22, 2012 | 08:19 AM
JagV8's Avatar
First rad I've seen like that on here or the UK forum in tens of thousands of posts.
Old Apr 22, 2012 | 08:45 AM
Mikey's Avatar
Me too. I thought the plastic end tanks were the toughest parts of a modern rad.
OP- have you taken it to a rad shop for their opinion and possible repair?
Old Apr 22, 2012 | 11:04 AM
crocodile62's Avatar
I have changed the end parts of the OEM rad with aluminum (race rad shop could do it)
The most important side is the intake where the hot water enter in the rad
sadepol01
16
Nov 22, 2024 05:05 PM
hoodun
Feb 20, 2023 05:52 AM
Mac Allan
Jul 20, 2020 05:46 PM
Johncy2000
Oct 2, 2015 01:05 AM
42Ajd
Sep 26, 2015 07:04 PM
