Radio GRRRRRRR
Old Oct 12, 2010 | 05:49 PM
desertdad's Avatar
Default Radio GRRRRRRR
OK everyone It is time for me to talk radios, the stock radio gets almost no reception AM or FM, and from what I have read installing a mp3 player is fairly involved. So here is a question for those of you with after market radios. What did you buy?
Old Oct 13, 2010 | 02:16 AM
2meke's Avatar
Hi, I removed stock radio and satnav(couldn't get disc for NZ)and custom made a panel out of perspex that could fit a DIN size standard head unit and a Garmin GPS. That was great until some ### stole the whole thing from my dash and left a big hole. I have yet to make another. I had a JVC DVD audio headunit which was great. I replacedit with a Blaupunkt MP3 player (which is currently just sitting in that big hole). I didn't like the original in my 99 S-type as it only played CDs. I had no issue with the radio, which hadgreat reception. I think your problem may be with the aerial, which has an amplifier for the signal (which I think is in the trunk/boot), but have a look on the JTIS. That is the most likely cause. Otherwise, if you had spare headunit/radio you could remove the factory radio and temporarily wire it in and use the aerial/antenna connection in the car. If you get good signal, then the factory radio is faulty, if not it is probably the aerial amplifier or wiring associated with that and the aerial.
Old Oct 13, 2010 | 08:01 AM
motorcarman's Avatar
Here are some old TSBs for the S-Type radio faults
bob gauff
File Type: pdf
File Type: pdf
Old Oct 13, 2010 | 09:07 AM
tcarby's Avatar
I have a 95 XJ6 VDP. I just had a Kenwood satelite radio installed along two new speakers in the front doors. The shop that actually did the work took the face plate off the old Jag radio and remanufactured it to fit the curved part of the dash. It cost $600 almost half of which was labor. No commercials, especially now with nothing but political comercials.
Old Oct 13, 2010 | 09:59 AM
desertdad's Avatar
Thank you for your responses, I am hoping to get more. I will check the trunk thanks for the tsb's
Old Oct 14, 2010 | 04:11 PM
desertdad's Avatar
No one else has thought about changing out the cassette tape deck head unit in their s-types? I like the look of the stock unit but in this day and age of mp3 technology I am finding this hard to believe.
Old Oct 14, 2010 | 04:21 PM
JOsworth's Avatar
Yes many have. First things first... We would need to know what year your car is.. That makes a world of difference. First gen cars had Ford stereos and the second gen had head units that were used in just Jaguars.
There are plenty of aftermarket fitment kits and wire harness adapters. Actually Crutchfield just started carrying both kits...
Old Oct 16, 2010 | 09:06 AM
desertdad's Avatar
Default Information
Jeff thank you for pointing out I did not mention what year S-type I have, I thought it was in my signature. It is a 2000. I went through Crutchfield and every head unit they list calls for modification. A process that I have not done in quite a while.
oldjaglover
Dec 25, 2024 04:33 PM
Paora
Feb 4, 2021 12:36 AM
philwarner
Jan 31, 2016 09:36 AM
ziondio
Sep 28, 2015 11:24 AM
