Radio not finding stations
Old Oct 31, 2024 | 10:15 AM
jimjags's Avatar
Default Radio not finding stations
I have a problem, I removed all connections to the radio and reconnected, all is great, even MW stations. A day later, back to normal. I have replaced radio with another unit and still have the same problem. Removed amplifier connector in rear `C' pillar radio dropped off when I removed cable and signal back on again when I reconnected, however signal just drops to hissing! Please Help. I don't mind an alternative such as a booster in 12V socket in armrest. CD Player works Ok. Don't think my model has Bluetooth though!
TIA
Jim
Old Nov 5, 2024 | 09:46 AM
M-e-l-l-o-w's Avatar
Does your rear heated screen work as it should?
Old Nov 5, 2024 | 12:01 PM
jimjags's Avatar
Hi,
Thanks for the input. Rear screen does work, although a bit hard to tell if 100% as it is so mild.
Does my model have bluetooth?
Old Nov 5, 2024 | 12:48 PM
JagV8's Avatar
What _is_ your model?
Old Nov 6, 2024 | 02:56 AM
jimjags's Avatar
Sorry, thought is showed on my profile?
Jaguar S-Type 2.7TD 2005 114000miles
Regards
Jim
Old Nov 6, 2024 | 11:32 AM
kr98664's Avatar
Isn't the antenna embedded in the rear window? Perhaps that connector got knocked loose when you were working in the C pillar area?
Old Nov 11, 2024 | 08:01 AM
jimjags's Avatar
Didn't touch anything when I inspected the amplifier in `C' pillar. What is odd is the radio works fine when I disconnect the 2 connectors in the rear of radio. Then a day later signal drops out, so tend to think it is the radio, then again I replaced the radio and got same symptoms!
F-type-r-2022
Oct 18, 2022 03:50 AM
Rdlane
Dec 30, 2013 09:49 AM
bharvey622
Aug 26, 2013 06:26 AM
fourbyfourbyfar
Oct 31, 2009 03:02 PM
