06 V8 NA- hard to start after engine is warm.
Old Nov 11, 2024 | 02:18 PM
ampiko's Avatar
Default 06 V8 NA- hard to start after engine is warm.
Cranks up fine when cold.
Once the car is at normal temp and i have been driving for 15 minutes and making two trips. The third trip, I have to press the pedal slightly and then turn on the ignition for the car to start. So far, I have replaced MAF, fuel filter, fuel rail sensor, O2 sensors. What is the fuel pressure that i should see when starting ? Thinking of replacing the Fuel Pump Assembly XR852870 , it is expensive. So any other ideas before i go ahead ? Thank you
Old Nov 11, 2024 | 02:36 PM
JagV8's Avatar
Use OBD to check things for sanity.
Especially IAT & ECT as it's relying on them (partly) to get fuel/air mix right.
Another not likely possibility would be a dribbly injector.
Old Nov 11, 2024 | 02:45 PM
ampiko's Avatar
What parameters should i read via the OBD scanner: Before cranking and then after cranking ? Also What is IAT and ECT ? Thanks
Old Nov 11, 2024 | 05:29 PM
JagV8's Avatar
See my sig
or web search such as
obd iat
obd ect
jordanmc
Nov 9, 2023 10:37 AM
Maxter25
Jun 6, 2023 06:43 PM
Tom Willey
Jul 29, 2020 08:54 AM
Mike Sarli
Feb 16, 2016 11:53 AM
BrightonRay
Nov 13, 2013 01:54 AM
