Car won't start - P0193
Old Jul 27, 2020 | 01:02 PM
Tom Willey's Avatar
Default Car won't start - P0193
Hi Guys, I have a 2009 XF Premium Luxury. About 5 month ago, my check engine light came on and the car was diagnosed with a P0193. At the time, my mechanic cleaned the MAF and replaced the Fuel rail pressure sensor, cleared the codes and I was good to go. About 3 months later, (not many miles) P0193 came back again. This time I did some so debug. I checked that the connector was good and that voltage (5v) and ground was good. I replaced the sensor and that appeared to fixed it. On Saturday, the code came back. On Sunday morning, the car wouldn't. start ... the engine just continually cranks. I tried pumping the accelerator a few times and once it almost started but quickly died. I changed the fuel filter but that didn't make any difference. After cranking I can smell fuel. So I'm assuming that my fuel pump is good
It would seem unlikely that I have had two sensors go bad. Incidentally, when I removed the vacuum line from the sensor, a small amount of fuel leaked out. Is this normal?
Anyone have any suggestions?
Tom
Old Jul 29, 2020 | 08:54 AM
clubairth1's Avatar
Community Influencer
Do you have any pressure at the fuel rail?
Cycle the key on and off several times before cranking. Does it start any better?
I think this is pointing to a fuel pump problem?
I had the exact same code on my old 2005 STR which had the 4.2L V-8. I "think" you do too but it was not listed so I am guessing?
But replacing the fuel pressure sensor which is mounted on the engine did fix my code for good.
Softball60
Jun 12, 2020 04:08 PM
euphonium01
Mar 30, 2018 05:05 PM
goodgame
Nov 21, 2017 10:14 PM
1320racer
Aug 24, 2016 12:42 PM
mikeeadyjr
Jun 19, 2013 08:50 AM
