Rear Diff Noise -
Old Dec 20, 2016 | 05:13 PM
Sixx Dogg's Avatar
Default Rear Diff Noise -
Good evening everyone!
A few years ago under warranty, I had the rear diff replaced because of that whine noise...well last night, I was driving on the highway, at around 115KM an hour, when I would release my foot off the gas pedal, I would hear something like a grinding noise for a brief second, it happened a couple times, then Restricted Performance came on for about 3 min then shut off.
Following this, drove home from an xmas party, about 40 min....and the car was fine. The temp last night was -15C.
Any advice fellas?
Thank you as always
SIXX
Old Dec 20, 2016 | 05:17 PM
JagV8's Avatar
I can't see a diff causing RP so likely something else - bearing maybe? Can upset (ABS) speed sensor.
Old Dec 20, 2016 | 05:21 PM
Sixx Dogg's Avatar
Thank you for the quick response.
Where would this bearing be located?
Old Dec 20, 2016 | 05:31 PM
JagV8's Avatar
LOL - sorry - I meant a wheel bearing. They're the ones that affect the ABS sensors.
Old Dec 20, 2016 | 05:44 PM
Sixx Dogg's Avatar
lol..
I appreciate your time thank you.
Is this an easy fix to replace? I am just happy it wasn't my rear diff failing again!
phew!!
Old Dec 20, 2016 | 05:57 PM
JagV8's Avatar
I can't _guarantee_ it's not the diff, though I can't see how it would cause what you report.
The workshop manual is free to download (or v cheap on ebay) and also someone's likely posted about diagnosing / changing a bearing (I dimly recall they have). Plus which parts are OK and affordable. Search (top of forum) is useful...
Often a bearing makes more noise when turning left (or right) than the other way, for example.
Old Dec 20, 2016 | 06:41 PM
Sixx Dogg's Avatar
Fingers crossed it isn't!
yup - been reading a bunch of stuff on everything here!
This site is so useful.
Old Dec 20, 2016 | 08:08 PM
Gus's Avatar
Gus
Are you sure it was from the differential or could it be from the drivetrain? Any way of having the OBDII codes read? If you have any codes please post the codes not what they tell you it means.
Old Dec 21, 2016 | 03:26 PM
Sixx Dogg's Avatar
Good afternoon, went into restricted performance mode - twice today.
both times I read it...code P0305 came up.
I cleared code once. Right now engine light is still on...I didn't clear it.
Old Dec 21, 2016 | 03:30 PM
JagV8's Avatar
You can just look that up in the freely downloadable jag doc which gives the known causes.
(May as well get the whole free workshop manual but the codes PDF is also separate if you just want that.)
Commonly a coil (for the spark plug). Nothing at all to do with the rear of the car.
Old Dec 21, 2016 | 03:41 PM
Sixx Dogg's Avatar
Thank you for your advice! Is #5 on the easy to get at side of the engine?
I just recently in the past couple weeks had two of them done. One on easy side, and the one in the middle on the hard side that my mechanic was able to get out without removing anything to get access to it.
Old Dec 21, 2016 | 03:43 PM
JagV8's Avatar
It's all in the free stuff. Just get and read...
Also in previous posts, free via Search.
Old Dec 21, 2016 | 05:26 PM
Sixx Dogg's Avatar
Numbering;
FRONT OF CAR
4 1
5 2
6 3
REAR OF CAR
My car is a 2006.
Good news is, it is on the easy side - phew...unless what I found was in correct.
I will keep you guys posted tomorrow on my fix!
Love this site.
Old Dec 21, 2016 | 05:33 PM
JagV8's Avatar
Well that's right up to 2002.5MY (2003 USA) but not for more recent - and of course is the V6 only (make the obvious changes for V8).
This is why one should get the free downloads as they show the right stuff first time.
Old Dec 21, 2016 | 05:53 PM
Sixx Dogg's Avatar
I did a search and that is what I got for the v6 on this site.
I am not savy on vehicles at all.
My car is a v6.
Back to the drawing board.
Old Dec 21, 2016 | 06:10 PM
Sixx Dogg's Avatar
Looks like #5 is on the **** side.
Of course just my luck!
Old Dec 21, 2016 | 08:24 PM
Here you go, it's under the manifold at the back.
Old Dec 21, 2016 | 08:34 PM
Gus's Avatar
Gus
Use this link for your cylinder numbering. Go to page 14
Link http://www.jagrepair.com/images/Auto...sb_09_2003.pdf
Take it from one who knows change all your plugs and coilpacks. You will regret it if you don’t.
Old Dec 21, 2016 | 09:51 PM
Sixx Dogg's Avatar
Thank you so much guys. I'm very grateful!! Woo !!
Old Dec 22, 2016 | 12:45 AM
JagV8's Avatar
But get with downloading JTIS, codes PDF etc.
