Rear Parking sensor problem on S type
Old Apr 10, 2013 | 05:11 PM
winjenkins's Avatar
Hi Jumping Jag Flash - Thanks for the advice but I understand that sometimes these added parking sensor systems are connected to the reversing lights circuit so pulling the fuse might switch off these lights as well.
Old Apr 11, 2013 | 09:19 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
Yeah, wouldn't want to see you pulling the fuse for other accessories. Just suggesting this option if you find a fuse dedicated to the parking sensor system.
Good luck,
Steve
Old Mar 31, 2016 | 12:57 PM
Jtpjag's Avatar
Thank all of you including the problem car. I have been dealing with the same issue for some time. I found the module but was afraid to undo anything. I tried looking for the fuse as well with not much luck yet. I will work on this rain permitting this weekend. I have a 2003 S Type Jag 3.0 L engine with a 5 speed trans. The trunk seems to be leaking now as well which may have caused the problem. Again thank you
Old Mar 31, 2016 | 03:56 PM
gm_jim's Avatar
Both of my earlier S-Types (2000, 20002) had water intrusion problems in the trunk that damaged the modules. I looked on Ebay but every one I saw had evidence of water having made contact. Look for white chalky deposits on the outside any used module (front and back). If they're there it means its been in contact with water.
I finally gave up on the sensors. A brand new module was out of my price range. My 2005 doesn't have the water entry issues the earlier S-Types had.
Old Apr 1, 2016 | 04:14 PM
Jtpjag's Avatar
Thank you, That helps
Old Aug 1, 2020 | 03:28 PM
FhvnEd's Avatar
My 2005 S-Type VDP Edition started having trunk water entry problems recently. I waited for a dry day and turned a hose on the trunk and checked the entire gasket surrounding the trunk lid. I applied silicone sealant all along the side of the gasket and the water stopped penetrating. I also drilled 2 3/4" holes in the lowest part of the trunk beneath the spare tire as drain holes and haven't had any water problems since. Now if I could say the same thing about my sun roof.
stanjag
Dec 29, 2024 08:26 PM
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
tberg
Aug 31, 2015 04:33 PM
dpappyp
Aug 27, 2015 06:31 AM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
